Blinking cursor on boot (toshiba satellite a15) (alt+f1 does not work)
    I have downloaded the kubuntu-6.06.1-alternate-i386.iso (intel x86 dapper drake release of kubuntu), burned to a cd booted into it then chose the install option. After installation and rebooting i only get a blinking cursor upon bootup. (at the end of installation there were two small grey box's on screen)
    I have tried many key combinations which are not bringing up a command prompt.....The keyboard does beep when trying these.
    Note, the hard drive was previously formatted ntfs with winxp and I have used boot and nuke to wipe. Below is the cpuz output from the toshiba laptop i am trying this installation on.
    Number of processors 1
    Number of cores 1 per processor
    Number of threads 1 (max 1) per processor
    Name Intel Celeron
    Code Name Northwood
    Specification Mobile Intel(R) Celeron(R) CPU 2.00GHz
    Package Socket 478 mPGA
    Family/Model/Stepping F.2.9
    Extended Family/Model F.2
    Brand ID 15
    Core Stepping D1
    Technology 0.13 um
    Core Speed 1995.0 MHz
    Multiplier x Bus speed 20.0 x 99.7 MHz
    Rated Bus speed 399.0 MHz
    Stock frequency 2000 MHz
    Instruction sets MMX, SSE, SSE2
    L1 Data cache (per processor) 8 KBytes, 4-way set associative, 64-byte line size
    Trace cache (per processor) 12 Kuops, 8-way set associative
    L2 cache (per processor) 256 KBytes, 4-way set associative, 64-byte line size
    Chipset & Memory
    Northbridge Intel i852GM rev. A1
    Southbridge Intel 82801DB (ICH4-M) rev. 03
    Memory Type DDR
    Memory Size 256 MBytes
    Memory Frequency 133.0 MHz (3:4)
    CAS# Latency (tCL) 2.5 clocks
    RAS# to CAS# (tRCD) 3 clocks
    RAS# Precharge (tRP) 3 clocks
    Cycle Time (tRAS) 6 clocks
    System
    System Manufacturer TOSHIBA
    System Name Satellite A15
    System S/N 83066786H
    Mainboard Vendor TOSHIBA
    Mainboard Model Portable PC
    BIOS Vendor TOSHIBA
    BIOS Version Version 1.30
    BIOS Date 09/02/2003
    Memory SPD
    Module 1 DDR, PC2100 (133 MHz), 256 MBytes, Hyundai Electronics
    Note this question is also posted here http://www.experts-exchange.com/OS/L..._22876131.html
    Re: Blinking cursor on boot (toshiba satellite a15) (alt+f1 does not work)
    First, the obvious question: when you booted from the LiveCD, did you get to the desktop, i.e., did the LiveCd fully boot up?
      Yes, when booting to the live cd it was very nice. Everything worked including my pcmcia network card.
        Originally posted by acidque
        ...including my pcmcia network card.
        Do you remember if you had working sound when you booted from the LiveCD?
        You loose nothing by trying this: remove your network card and reboot to see if you get to the desktop. If this works, insert the network card and see if it gets recognized and you are able to surf the Net. Please post the results of this test.
          The dapper drake live cd does the same. (blinking cursor in upper right on boot) keyboard beeps but no key combination will allow a command prompt. I had used the Feisty Fawn live cd which worked but did not install correctly. (after installation the two small grey box's appeared on boot)
            It sounds to me as though you have the wrong graphics driver enabled (correct if I'm wrong Snowhog, I'm always learning); what graphics card do you have?
            Asus G1S-X3:
            Intel Core2 Duo T7500, Nvidia GeForce 8600M GT, 4Gb PC2-5300, 320Gb Hitachi 7k320, Linux ( )
              The toshiba website spec for my specific laptop is (Intel 852 GM 32mb integrated graphics controller) W/32mb internal shared video memory.
                Do you know which driver you have enabled?
                Asus G1S-X3:
                  No, How do i determine the driver used for the dapper drake live cd on boot? I cannot get to a command prompt when the live cd loads.
                    If you don't know, let's skip that step for now. Reboot your computer and press the "Esc" key when prompted to cancel the normal boot process (this should be right after BIOS finishes loading everything it does); choose the option to start Kubuntu in recovery mode (if there are multiple options for this, it doesn't really matter which you choose). This should open up a command prompt. Type "dpkg-reconfigure -phigh xserver-xorg"; just choose the default options for everything except what driver you want to use. Choose "vesa" as the graphics driver. Then once you finish everything, type "reboot" - this command will "reboot" your computer.
                    Let it boot normally, and let me know if you get anything different.
                    Oh, in case you don't know, ignore the " " marks, they are only for reference and clarification purposes and not to be included with the commands.
                    Asus G1S-X3:
                      ok Tried to press exc key using the live dapper cd but no response. Keyboard beep'd.
                      Also tried using the dapper alt install cd. After entering the command i get back (could not find kernel image: dpkg-reconfigure
                      boot:
                        So are you getting the blinking cursor on the Live CD or after you've installed Kubuntu and rebooted your computer (i.e. booted from your hard drive and "not" the Live CD)?
                        Asus G1S-X3:
                          both.
                          1) with the live dapper drake cd i get the blinking cursor on boot
                          2) after installing using the alternate(x86) install cd i get the blinking cursor on boot
                            Alright, try my instructions without the Live CD, just booting from your hard drive. Immediately after your BIOS finishes loading, without the Live CD in your computer, you should see the prompt to press the "Esc" button and given 2-3 seconds to do so.
                            Asus G1S-X3:
                              I allowed the bios to load then immediately afterward i pressed the esc key....nothing...I did not get the command prompt after pressing the esc key after bios POST.
