I've posted this item in the software section without any luck (so far) so I'm hoping you hardware blokes can help me
My machine was connected via a D-Link DI-514 router, and although this is a wireless router, I was connected with a wired connection. I used Privoxy for web content filtering and Popfile for email classification. Both proxies were running on 127.0.0.1
However, when I added a wireless card to my PC, I found I could not connect via 127.0.0.1 or localhost. Remove proxies from my web browser and connection was made. I could not connect with my ISPs email server either, until I connected directly and not through Popfile.
My wife's Windows machine is on the LAN and through a wired connection. She uses Privoxy and Popfile as well, and connects through them. Its definitely something to do with my wireless card, which is a Gigabyte GN-WPKG 802.11 b/g card.
Does anyone know the cure for this, since I do not want to be without web filtering or email classification facilities.
Thanks in advance
Thanks in advance
