audio problem
    audio problem
    After installing kubuntu I cannot get audio with amarok. help.
    thanks,
    loraine0622
    Re: audio problem
    Open Konsole via:
    K Menu --> System --> Konsole
    and type:
    sudo apt-get install libxine-extracodecs
    Let us know if that works.
      Re: audio problem
      thanks for your help proteus71, i did try your suggestion and received an error message. i scrolled through the available pkgs on synaptic and downloaded some audio pkgs. i have audio now, not sure what worked. i'm still learning linux and kubuntu, it's a process and i'm having fun. thanks for your response.
      loraine0622
