Mouse cursor problem with fglrx on Radeon 9200
    Hi
    I am using Dapper Beta on my comp with my Radeon 9200 DDR card. I had to use an option "sw_cursor" "On" to fix the brightness bug on that driver. But now, the cursor is a little corrupted, especially when scrolling in the browser or navigating in the menu. Also, the resolution 1400x1050 is not supported by the driver, it works in 1280x1024 now. I have the original driver from ubuntu repo.
    What can I do? is there any option that I should enable or disable? thx much
    Re: Mouse cursor problem with fglrx on Radeon 9200
    There is nobody in this world who have a problem with the cursor and the brightness on Radeon 9200 card? I am alone?
