Desktop problem
    [LAPTOP] Desktop problem
    Hello.
    As the photo is opened during the desktop, it gives an error. What is the problem and how do I fix it?
    I am using kubuntu 18.04.1
    Regards
    you are going to half to be a bit more descriptive ,,,what photo , the desktop wallpaper?
    whats the error your getting ?
    EDIT: ok you added a screenshot ,,,,,,
    is this a clean install or upgrade and on what kind of hardware .
      vinnywright thanks for reply. I am not getting the error as a message. it only opens on the desktop as in the example.
        @lavinya28: Welcome to Kubuntu! I'm sure we can fix your error, but it's really important to know if you did a clean install of 18.04.1, or if you did an upgrade directly from some other version or distro.
        If you can open a konsole command line session, it would be helpful in getting some specific system info. If you can, in a konsole, enter this:
        inxi -Fxz
        And if inxi is not loaded, and you have an internet connection, enter following to install inxi:
        sudo apt install inxi
        Then copy the output into a CODE box (the # button at the top of the reply box).
          Not an answer but the image you uploaded is exactly the same screen as I got when I was trying to use two monitors using hdmi - so do you perhaps have a second monitor connected?
