Freezing System with intermittant TTY change ability on my PC
    Originally posted by phonic-otg View Post
    I am beginning to think it may be wise to revert to 16.04.4 on Brtfs drive as suggested by Grey Geek.
    I never had the freeze issues with 16 just the random screen blink or blinking.
    At the lest I would give this solution a try: https://github.com/r4m0n/ZenStates-Linux
      Should be removed.
      I have abandoned this install. Hopefully my other install on UEFI SSD with BTRFS will overcome the quirkiness of this one.
        Your "other install" can't affect the quirky one, unless you've mixed the installations by cross polinating subvolumes, or using chroot!
          Thanks
