14.04 boot problem....
    After switching on the device it restrarts and ends up in Grub menu.
    And I have to manually change
    [FONT=arial black]set root='hd0,msdos1'[/FONT]
    to
    [FONT=arial black]set root=(hd0,msdos1)[/FONT]
    And manually add
    • (hd0,msdos1)
    right before /boot in linux and initrd commonds:
    [FONT=arial black]
    linux     (hd0,msdos1)/boot/blabla[/FONT]
    [FONT=arial black]initrd    (hd0,msdos1)/boot/blabla
    [/FONT]
    How can I fix this problem.
    Normally this would be fixed by editing groot in menu.lst, but grub seems to no longer generate or use this!
    Wish they'd stop changing stuff that works.
      Grub Customizer might have the settings you need:
      http://ubuntuguide.org/wiki/Ubuntu:T...Grub2_settings
        TNX. I installed grub-customizer. Will post the result after reboot.
          Have you tried boot repair? you can find it here: https://help.ubuntu.com/community/Boot-Repair
