Muon in System Settings
    In previous releases of Kubuntu, the Add/Remove Software/Package Manager (Muon) was part of Systems Settings. In the latest release, Muon is a seperate item that it not accessible in the System Settings. A minor issue, agreed. But I liked having all of my settings in one spot. Now I have two menu items, one for System Settings and one for Muon and I think it looks cluttered.
    Is there anyway to add back in Package Manager to System Settings?
    Registered Linux user #346571
    Apper ?
    - http://en.wikipedia.org/wiki/Apper
    - http://userbase.kde.org/KPackageKit
    apt-cache show apper
    Package: apper
    Priority: optional
    Section: universe/kde
    Description-en: KDE package management tool using PackageKit
    PackageKit allows performing simple software management tasks over a DBus
    interface e.g. refreshing the cache, updating, installing and removing
    software packages or searching for multimedia codecs and file handlers.
    This package provides a KDE package manager based on PackageKit,
    as well as package management support for the KDE desktop.
    It implements the PackageKit session API for KDE, which allows
    applications to easily install additional software (e.g. extensions),
    uninstall files and perform simple software status queries.
    Homepage: http://kde-apps.org/content/show.php...?content=84745
      Generic - KDE System Settings
      The KDE System Settings eats desktop files and outputs...
      Making: muon-system-settings.desktop
      [Desktop Entry]
      Name=Muon in System Settings
      Comment=Kubuntu package manager
      Exec=muon
      Icon=muon
      Type=Service
      Encoding=UTF-8
      X-KDE-SubstituteUID=true
      X-KDE-ServiceTypes=KCModule
      X-KDE-ParentApp=kcontrol
      X-KDE-Keywords=package, manager, muon
      X-KDE-System-Settings-Parent-Category=system-administration
      X-KDE-Weight=60
      Categories=Qt;KDE;System;
      GenericName=Muon Package Manager
      and dropping it to the /usr/share/kde4/services/
      then the Muon package manager is in the KDE System Settings.
        Apper did the trick! Thanks. I'll keep this for the later info as well. Excellent information!
