after upgrade to kubuntu 13.04 kio-mtp not work
    after upgrade to kubuntu 13.04 kio-mtp not work.
    With 12.10 no problems, but after upgrade to 13.04 i have problem, dolphin not display mtp icon, i remove kio-mtp with purge , and install now,- problem continue.
    Sometimes it helps to just open dolphin, and use the sidebar and click on the icon there rather than using the pop-up notifications etc.
    Can you explain more carefully by what you mean that it doesn't work?
      I not see mtp icon on dolphin
        with 12.10 no problem , i connect android device, and dolphin show mtp icon for connecting to device
          I repeat. Plug the device in. Close any and all file managers. Then open dolphin, on the bar on the left you should see the device name, click on it, it may spew out an error. Click on the icon again. Is it working? Also is the MTP KIO-slave installed?
            kio-mtp at here:
            :~$ apt-cache policy kio-mtp
            kio-mtp:
            Installed: 0+git20130315-0ubuntu1
            Candidate: 0+git20130315-0ubuntu1
            Version table:
            *** 0+git20130315-0ubuntu1 0
            500 http://fi.archive.ubuntu.com/ubuntu/ raring/universe amd64 Packages
            100 /var/lib/dpkg/status
            Plug the device in
            Is the device detected (lsusb)?
            At here:
            :~$ lsusb
            Bus 001 Device 004: ID 04e8:6860 Samsung Electronics Co., Ltd GT-I9100 Phone [Galaxy S II], GT-P7500 [Galaxy Tab 10.1]
            Dolphin - type the kio protocol to the Dolphin navigation line:
            mtp:/
            At here:
            How about there ?
            Before you edit, BACKUP !
            Why there are dead links ?
            2. Thread: Lost Information
