Help needed for "Backtab" as shortcut key
    I'm trying to set the shortcut for "Walk Through Windows Alternative (Reverse)" as "Ctrl+Alt+Shift+Backtab" same as "Walk Through Windows (Reverse)" is set to "Alt+Shift+Backtab".
    But I'm unable to add Backtab in the shortcut.
    Tried to google it... But not much help found.
    Is any one facing similar issue ?
    If you just press ctrl-alt-shift-tab do you get the result you want? It looks like it doesn't work - at least not for a shortcut I have set as Meta-Shift-Tab - I hadn't though about this before.
    My web searching yielded this:
    You can manually edit ~/.kde4/share/config/kglobalshortcutsrc
    and then reload it via
    kquitapp kglobalaccel && sleep 2s && kglobalaccel &
    Worked for me.
    I think this indicates a bug in the relevant system settings module. Does anyone else have this issue?
      Thanks man,
      Worked like charm..
