[SOLVED] Dell Latitude 2100 and Wireless B43 not working
    This is what network manager states:
    Type: Wireless 802.11
    Connection State: Unavailable
    IP Address: No IP address.
    Connection Speed: Unknown
    System Name: wlan0
    MAC Address: 70:1A:04:XX:XX:XX
    Driver: b43
    Can anyone help debug/fix this?
    Thanks,
    Gareth
    Using a Novatech X16 NV Pro
    Re: Dell Latitude 2100 and Wireless B43 not working
    Look to your dmesg output and see what the driver and interface are doing.
    Check the interface is in state "up" in ifconfig.
    Report back with more info
    Intocabile
      Dmesg output:
      Lots of stuff in there about b43 firmware errors:
      [quote][ 0.000000] Initializing cgroup subsys cpuset
      [ 0.000000] Linux version 2.6.38-8-generic (buildd@vernadsky) (gcc version 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu3) ) #42-Ubuntu SMP Mon Apr 11 03:31:50 UTC 2011 (Ubuntu 2.6.38-8.42-generic 2.6.38.2)
      [ 0.000000] BIOS-provided physical RAM map:
      [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
      [ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
      [ 0.000000] BIOS-e820: 0000000000100000 - 000000007f6c1400 (usable)
      [ 0.000000] BIOS-e820: 000000007f6c1400 - 0000000080000000 (reserved)
      [ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
      [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
      [ 0.000000] BIOS-e820: 00000000fed18000 - 00000000fed1c000 (reserved)
      [ 0.000000] BIOS-e820: 00000000fed20000 - 00000000fed90000 (reserved)
      [ 0.000000] BIOS-e820: 00000000feda0000 - 00000000feda7000 (reserved)
      [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
      [ 0.000000] BIOS-e820: 00000000ffe00000 - 0000000100000000 (reserved)
      [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled in hardware: non-PAE kernel!
      [ 0.000000] NX (Execute Disable) protection: approximated by x86 segment limits
      [ 0.000000] DMI 2.4 present.
      [ 0.000000] DMI: Dell Inc. Latitude 2100 /0W785N, BIOS A02 08/11/2009
      [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
      [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
      [ 0.000000] last_pfn = 0x7f6c1 max_arch_pfn = 0x100000
      [ 0.000000] MTRR default type: uncachable
      [ 0.000000] MTRR fixed ranges enabled:
      [ 0.000000] 00000-9FFFF write-back
      [ 0.000000] A0000-BFFFF uncachable
      [ 0.000000] C0000-CFFFF write-protect
      [ 0.000000] D0000-EFFFF uncachable
      [ 0.000000] F0000-FFFFF write-protect
      [ 0.000000] MTRR variable ranges enabled:
      [ 0.000000] 0 base 000000000 mask 000000000 write-back
      [ 0.000000] 1 base 0E0000000 mask 0E0000000 uncachable
      [ 0.000000] 2 base 07F800000 mask 0FF800000 uncachable
      [ 0.000000] 3 base 07F700000 mask 0FFF00000 uncachable
      [ 0.000000] 4 disabled
      [ 0.000000] 5 disabled
      [ 0.000000] 6 disabled
      [ 0.000000] 7 disabled
      [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
      [ 0.000000] e820 update range: 000000007f700000 - 0000000080000000 (usable) ==> (reserved)
      [ 0.000000] initial memory mapped : 0 - 01c00000
      [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
      [ 0.000000] 0000000000 - 0000400000 page 4k
      [ 0.000000] 0000400000 - 0037400000 page 2M
      [ 0.000000] 0037400000 - 00377fe000 page 4k
      [ 0.000000] kernel direct mapping tables up to 377fe000 @ 1bfb000-1c00000
      [ 0.000000] RAMDISK: 35d42000 - 36e99000
      [ 0.000000] ACPI: RSDP 000fbec0 00024 (v02 DELL )
      [ 0.000000] ACPI: XSDT 7f6c3e00 0005C (v01 DELL M09 27D9080B ASL 00000061)
      [ 0.000000] ACPI: FACP 7f6c3c9c 000F4 (v04 DELL M09 27D9080B ASL 00000061)
      [ 0.000000] ACPI: DSDT 7f6c4400 04813 (v02 INT430 SYSFexxx 00001001 INTL 20050624)
      [ 0.000000] ACPI: FACS 7f6d2c00 00040
      [ 0.000000] ACPI: HPET 7f6c3f00 00038 (v01 DELL M09 00000001 ASL 00000061)
      [ 0.000000] ACPI: APIC 7f6c4000 00068 (v01 DELL M09 27D9080B ASL 00000047)
      [ 0.000000] ACPI: ASF! 7f6c3c00 00076 (v32 DELL M09 27D9080B ASL 00000061)
      [ 0.000000] ACPI: MCFG 7f6c3fc0 0003E (v16 DELL M09 27D9080B ASL 00000061)
      [ 0.000000] ACPI: SLIC 7f6c409c 00176 (v01 DELL M09 27D9080B ASL 00000061)
      [ 0.000000] ACPI: SSDT 7f6c2325 0066C (v01 PmRef CpuPm 00003000 INTL 20050624)
      [ 0.000000] ACPI: Local APIC address 0xfee00000
      [ 0.000000] 1150MB HIGHMEM available.
      [ 0.000000] 887MB LOWMEM available.
      [ 0.000000] mapped low ram: 0 - 377fe000
      [ 0.000000] low ram: 0 - 377fe000
      [ 0.000000] Zone PFN ranges:
      [ 0.000000] DMA 0x00000010 -> 0x00001000
      [ 0.000000] Normal 0x00001000 -> 0x000377fe
      [ 0.000000] HighMem 0x000377fe -> 0x0007f6c1
      [ 0.000000] Movable zone start PFN for each node
      [ 0.000000] early_node_map[2] active PFN ranges
      [ 0.000000] 0: 0x00000010 -> 0x0000009f
      [ 0.000000] 0: 0x00000100 -> 0x0007f6c1
      [ 0.000000] On node 0 totalpages: 521808
      [ 0.000000] free_area_init_node: node 0, pgdat c1784100, node_mem_map f4d52200
      [ 0.000000] DMA zone: 32 pages used for memmap
      [ 0.000000] DMA zone: 0 pages reserved
      [ 0.000000] DMA zone: 3951 pages, LIFO batch:0
      [ 0.000000] Normal zone: 1744 pages used for memmap
      [ 0.000000] Normal zone: 221486 pages, LIFO batch:31
      [ 0.000000] HighMem zone: 2302 pages used for memmap
      [ 0.000000] HighMem zone: 292293 pages, LIFO batch:31
      [ 0.000000] Using APIC driver default
      [ 0.000000] ACPI: PM-Timer IO Port: 0x1008
      [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
      [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
      [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
      [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
      [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
      [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
      [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
      [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
      [ 0.000000] ACPI: IRQ0 used by override.
      [ 0.000000] ACPI: IRQ2 used by override.
      [ 0.000000] ACPI: IRQ9 used by override.
      [ 0.000000] Using ACPI (MADT) for SMP configuration information
      [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
      [ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
      [ 0.000000] nr_irqs_gsi: 40
      [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
      [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 0000000000100000
      [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:78000000)
      [ 0.000000] Booting paravirtualized kernel on bare hardware
      [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
      [ 0.000000] PERCPU: Embedded 13 pages/cpu @f7000000 s28800 r0 d24448 u2097152
      [ 0.000000] pcpu-alloc: s28800 r0 d24448 u2097152 alloc=1*4194304
      [ 0.000000] pcpu-alloc: [0] 0 1
      [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 517730
      [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.38-8-generic root=UUID=8ef10b03-644d-4749-ae97-3c0461560c91 ro quiet splash vt.handoff=7
      [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
      [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
      [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
      [ 0.000000] Initializing CPU#0
      [ 0.000000] allocated 10438100 bytes of page_cgroup
      [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
      [ 0.000000] Initializing HighMem for node 0 (000377fe:0007f6c1)
      [ 0.000000] Memory: 2032644k/2087684k available (5188k kernel code, 54588k reserved, 2540k data, 700k init, 1178380k highmem)
      [ 0.000000] virtual kernel memory layout:
      [ 0.000000] fixmap : 0xfff16000 - 0xfffff000 ( 932 kB)
      [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
      [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
      [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
      [ 0.000000] .init : 0xc178d000 - 0xc183c000 ( 700 kB)
      [ 0.000000] .data : 0xc15112a1 - 0xc178c480 (2540 kB)
      [ 0.000000] .text : 0xc1000000 - 0xc15112a1 (5188 kB)
      [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
      [ 0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
      [ 0.000000] Hierarchical RCU implementation.
      [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
      [ 0.000000] RCU-based detection of stalled CPUs is disabled.
      [ 0.000000] NR_IRQS:2304 nr_irqs:512 16
      [ 0.000000] CPU 0 irqstacks, hard=f3c08000 soft=f3c0a000
      [ 0.000000] Extended CMOS year: 2000
      [ 0.000000] vt handoff: transparent VT on vt#7
      [ 0.000000] Console: colour dummy device 80x25
      [ 0.000000] console [tty0] enabled
      [ 0.000000] hpet clockevent registered
      [ 0.000000] Fast TSC calibration using PIT
      [ 0.000000] Detected 1595.759 MHz processor.
      [ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency.. 3191.51 BogoMIPS (lpj=6383036)
      [ 0.004018] pid_max: default: 32768 minimum: 301
      [ 0.004077] Security Framework initialized
      [ 0.004115] AppArmor: AppArmor initialized
      [ 0.004119] Yama: becoming mindful.
      [ 0.004251] Mount-cache hash table entries: 512
      [ 0.004535] Initializing cgroup subsys ns
      [ 0.004544] ns_cgroup deprecated: consider using the 'clone_children' flag without the ns_cgroup.
      [ 0.004552] Initializing cgroup subsys cpuacct
      [ 0.004564] Initializing cgroup subsys memory
      [ 0.004584] Initializing cgroup subsys devices
      [ 0.004590] Initializing cgroup subsys freezer
      [ 0.004596] Initializing cgroup subsys net_cls
      [ 0.004602] Initializing cgroup subsys blkio
      [ 0.004675] CPU: Physical Processor ID: 0
      [ 0.004680] CPU: Processor Core ID: 0
      [ 0.004686] mce: CPU supports 5 MCE banks
      [ 0.004703] CPU0: Thermal monitoring enabled (TM2)
      [ 0.004712] using mwait in idle threads.
      [ 0.010858] ACPI: Core revision 20110112
      [ 0.020030] ftrace: allocating 23640 entries in 47 pages
      [ 0.024109] Enabling APIC mode: Flat. Using 1 I/O APICs
      [ 0.024515] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
      [ 0.066635] CPU0: Intel(R) Atom(TM) CPU N270 @ 1.60GHz stepping 02
      [ 0.068003] Performance Events: PEBS fmt0+, Atom events, Intel PMU driver.
      [ 0.068003] ... version: 3
      [ 0.068003] ... bit width: 40
      [ 0.068003] ... generic registers: 2
      [ 0.068003] ... value mask: 000000ffffffffff
      [ 0.068003] ... max period: 000000007fffffff
      [ 0.068003] ... fixed-purpose events: 3
      [ 0.068003] ... event mask: 0000000700000003
      [ 0.068003] CPU 1 irqstacks, hard=f3caa000 soft=f3cac000
      [ 0.068003] Booting Node 0, Processors #1 Ok.
      [ 0.008000] Initializing CPU#1
      [ 0.160044] Brought up 2 CPUs
      [ 0.160053] Total of 2 processors activated (6383.47 BogoMIPS).
      [ 0.160426] devtmpfs: initialized
      [ 0.164330] print_constraints: dummy:
      [ 0.164373] Time: 13:57:00 Date: 05/02/11
      [ 0.164463] NET: Registered protocol family 16
      [ 0.164491] Trying to unpack rootfs image as initramfs...
      [ 0.164898] EISA bus registered
      [ 0.164926] ACPI: bus type pci registered
      [ 0.165157] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
      [ 0.165170] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
      [ 0.165176] PCI: Using MMCONFIG for extended config space
      [ 0.165183] PCI: Using configuration type 1 for base access
      [ 0.165202] dmi type 0xB1 record - unknown flag
      [ 0.169669] bio: create slab <bio-0> at 0
      [ 0.173148] ACPI: EC: Look up EC in DSDT
      [ 0.182692] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
      [ 0.189016] ACPI: SSDT 7f6c2991 00281 (v01 PmRef BspIst 00003000 INTL 20050624)
      [ 0.189803] ACPI: Dynamic OEM Table Load:
      [ 0.189815] ACPI: SSDT (null) 00281 (v01 PmRef BspIst 00003000 INTL 20050624)
      [ 0.190382] ACPI: SSDT 7f6c2de9 005C6 (v01 PmRef BspCst 00003001 INTL 20050624)
      [ 0.191118] ACPI: Dynamic OEM Table Load:
      [ 0.191130] ACPI: SSDT (null) 005C6 (v01 PmRef BspCst 00003001 INTL 20050624)
      [ 0.192217] ACPI: SSDT 7f6c2c12 001D7 (v01 PmRef ApIst 00003000 INTL 20050624)
      [ 0.193075] ACPI: Dynamic OEM Table Load:
      [ 0.193088] ACPI: SSDT (null) 001D7 (v01 PmRef ApIst 00003000 INTL 20050624)
      [ 0.193449] ACPI: SSDT 7f6c33af 0008D (v01 PmRef ApCst 00003000 INTL 20050624)
      [ 0.194222] ACPI: Dynamic OEM Table Load:
      [ 0.194234] ACPI: SSDT (null) 0008D (v01 PmRef ApCst 00003000 INTL 20050624)
      [ 0.199842] ACPI: Interpreter enabled
      [ 0.200027] ACPI: (supports S0 S3 S4 S5)
      [ 0.200093] ACPI: Using IOAPIC for interrupt routing
      [ 0.273647] ACPI: EC: GPE = 0x1a, I/O: command/status = 0x934, data = 0x930
      [ 0.320529] ACPI: No dock devices found.
      [ 0.320540] HEST: Table not found.
      [ 0.320553] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
      [ 0.352971] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
      [ 0.417094] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
      [ 0.417108] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
      [ 0.417118] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
      [ 0.417127] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff]
      [ 0.417137] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xf7ffffff]
      [ 0.417146] pci_root PNP0A03:00: host bridge window [mem 0xfc000000-0xfebfffff]
      [ 0.417156] pci_root PNP0A03:00: host bridge window [mem 0xfec10000-0xfecfffff]
      [ 0.417165] pci_root PNP0A03:00: host bridge window [mem 0xfed1c000-0xfed1ffff]
      [ 0.417175] pci_root PNP0A03:00: host bridge window [mem 0xfed90000-0xfed9ffff]
      [ 0.417184] pci_root PNP0A03:00: host bridge window [mem 0xfeda7000-0xfedfffff]
      [ 0.417193] pci_root PNP0A03:00: host bridge window [mem 0xfee10000-0xff9fffff]
      [ 0.417203] pci_root PNP0A03:00: host bridge window [mem 0xffc00000-0xffdfffff]
      [ 0.417248] pci 0000:00:00.0: [8086:27ac] type 0 class 0x000600
      [ 0.417336] pci 0000:00:02.0: [8086:27ae] type 0 class 0x000300
      [ 0.417360] pci 0000:00:02.0: reg 10: [mem 0xf6f00000-0xf6f7ffff]
      [ 0.417375] pci 0000:00:02.0: reg 14: [io 0xeff8-0xefff]
      [ 0.417390] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff pref]
      [ 0.417406] pci 0000:00:02.0: reg 1c: [mem 0xf6ec0000-0xf6efffff]
      [ 0.417474] pci 0000:00:02.1: [8086:27a6] type 0 class 0x000380
      [ 0.417495] pci 0000:00:02.1: reg 10: [mem 0xf6f80000-0xf6ffffff]
      [ 0.417649] pci 0000:00:1b.0: [8086:27d8] type 0 class 0x000403
      [ 0.417686] pci 0000:00:1b.0: reg 10: [mem 0xf6ebc000-0xf6ebffff 64bit]
      [ 0.417807] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
      [ 0.417821] pci 0000:00:1b.0: PME# disabled
      [ 0.417873] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
      [ 0.417993] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
      [ 0.418005] pci 0000:00:1c.0: PME# disabled
      [ 0.418058] pci 0000:00:1c.1: [8086:27d2] type 1 class 0x000604
      [ 0.418178] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
      [ 0.418189] pci 0000:00:1c.1: PME# disabled
      [ 0.418244] pci 0000:00:1c.3: [8086:27d6] type 1 class 0x000604
      [ 0.418363] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
      [ 0.418374] pci 0000:00:1c.3: PME# disabled
      [ 0.418430] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
      [ 0.418512] pci 0000:00:1d.0: reg 20: [io 0xbf80-0xbf9f]
      [ 0.418580] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
      [ 0.418662] pci 0000:00:1d.1: reg 20: [io 0xbf60-0xbf7f]
      [ 0.418737] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
      [ 0.418822] pci 0000:00:1d.2: reg 20: [io 0xbf40-0xbf5f]
      [ 0.418892] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
      [ 0.418974] pci 0000:00:1d.3: reg 20: [io 0xbf20-0xbf3f]
      [ 0.419059] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
      [ 0.419100] pci 0000:00:1d.7: reg 10: [mem 0xfed1c000-0xfed1c3ff]
      [ 0.419230] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
      [ 0.419242] pci 0000:00:1d.7: PME# disabled
      [ 0.419293] pci 0000:00:1e.0: [8086:2448] type 1 class 0x000604
      [ 0.419416] pci 0000:00:1f.0: [8086:27b9] type 0 class 0x000601
      [ 0.419545] pci 0000:00:1f.0: quirk: [io 0x1000-0x107f] claimed by ICH6 ACPI/GPIO/TCO
      [ 0.419560] pci 0000:00:1f.0: quirk: [io 0x1080-0x10bf] claimed by ICH6 GPIO
      [ 0.419572] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0900 (mask 007f)
      [ 0.419585] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 0c80 (mask 003f)
      [ 0.419668] pci 0000:00:1f.2: [8086:27c5] type 0 class 0x000106
      [ 0.419712] pci 0000:00:1f.2: reg 10: [io 0x6e70-0x6e77]
      [ 0.419733] pci 0000:00:1f.2: reg 14: [io 0x6e78-0x6e7b]
      [ 0.419754] pci 0000:00:1f.2: reg 18: [io 0x6e80-0x6e87]
      [ 0.419775] pci 0000:00:1f.2: reg 1c: [io 0x6e88-0x6e8b]
      [ 0.419796] pci 0000:00:1f.2: reg 20: [io 0x6ea0-0x6ebf]
      [ 0.419818] pci 0000:00:1f.2: reg 24: [mem 0xfed1c800-0xfed1cbff]
      [ 0.419886] pci 0000:00:1f.2: PME# supported from D3hot
      [ 0.419898] pci 0000:00:1f.2: PME# disabled
      [ 0.419941] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
      [ 0.420042] pci 0000:00:1f.3: reg 20: [io 0x10c0-0x10df]
      [ 0.420187] pci 0000:00:1c.0: PCI bridge to [bus 0b-0b]
      [ 0.420200] pci 0000:00:1c.0: bridge window [io 0xf000-0x0000] (disabled)
      [ 0.420213] pci 0000:00:1c.0: bridge window [mem 0xfff00000-0x000fffff] (disabled)
      [ 0.420230] pci 0000:00:1c.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
      [ 0.420358] pci 0000:0c:00.0: [14e4:4315] type 0 class 0x000280
      [ 0.420403] pci 0000:0c:00.0: reg 10: [mem 0xf6dfc000-0xf6dfffff 64bit]
      [ 0.420560] pci 0000:0c:00.0: supports D1 D2
      [ 0.420568] pci 0000:0c:00.0: PME# supported from D0 D3hot D3cold
      [ 0.420581] pci 0000:0c:00.0: PME# disabled
      [ 0.428092] pci 0000:00:1c.1: PCI bridge to [bus 0c-0c]
      [ 0.428108] pci 0000:00:1c.1: bridge window [io 0xf000-0x0000] (disabled)
      [ 0.428123] pci 0000:00:1c.1: bridge window [mem 0xf6d00000-0xf6dfffff]
      [ 0.428140] pci 0000:00:1c.1: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
      [ 0.428285] pci 0000:09:00.0: [14e4:1684] type 0 class 0x000200
      [ 0.428336] pci 0000:09:00.0: reg 10: [mem 0xf6cf0000-0xf6cfffff 64bit]
      [ 0.428516] pci 0000:09:00.0: PME# supported from D3hot D3cold
      [ 0.428529] pci 0000:09:00.0: PME# disabled
      [ 0.436096] pci 0000:00:1c.3: PCI bridge to [bus 09-09]
      [ 0.436113] pci 0000:00:1c.3: bridge window [io 0xf000-0x0000] (disabled)
      [ 0.436129] pci 0000:00:1c.3: bridge window [mem 0xf6c00000-0xf6cfffff]
      [ 0.436147] pci 0000:00:1c.3: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
      [ 0.436291] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
      [ 0.436306] pci 0000:00:1e.0: bridge window [io 0xf000-0x0000] (disabled)
      [ 0.436320] pci 0000:00:1e.0: bridge window [mem 0xfff00000-0x000fffff] (disabled)
      [ 0.436339] pci 0000:00:1e.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled)
      [ 0.436351] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
      [ 0.436362] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
      [ 0.436373] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
      [ 0.436384] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
      [ 0.436395] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xf7ffffff] (subtractive decode)
      [ 0.436406] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfebfffff] (subtractive decode)
      [ 0.436417] pci 0000:00:1e.0: bridge window [mem 0xfec10000-0xfecfffff] (subtractive decode)
      [ 0.436429] pci 0000:00:1e.0: bridge window [mem 0xfed1c000-0xfed1ffff] (subtractive decode)
      [ 0.436440] pci 0000:00:1e.0: bridge window [mem 0xfed90000-0xfed9ffff] (subtractive decode)
      [ 0.436452] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfedfffff] (subtractive decode)
      [ 0.436463] pci 0000:00:1e.0: bridge window [mem 0xfee10000-0xff9fffff] (subtractive decode)
      [ 0.436474] pci 0000:00:1e.0: bridge window [mem 0xffc00000-0xffdfffff] (subtractive decode)
      [ 0.436522] pci_bus 0000:00: on NUMA node 0
      [ 0.436542] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
      [ 0.437308] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIE._PRT]
      [ 0.437666] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
      [ 0.437851] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
      [ 0.438051] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
      [ 0.438272] pci0000:00: Requesting ACPI _OSC control (0x1d)
      [ 0.464784] ACPI: PCI Interrupt Link [LNKA] (IRQs 10 *11)
      [ 0.465082] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7) *3
      [ 0.465298] ACPI: PCI Interrupt Link [LNKC] (IRQs 10 11) *0, disabled.
      [ 0.465550] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 7 *10 11)
      [ 0.465811] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 *7 10 11 12 14 15)
      [ 0.466114] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *10 11 12 14 15)
      [ 0.466386] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 10 11 12 14 15)
      [ 0.466652] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 *4 5 6 7 10 11 12 14 15)
      [ 0.467043] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks= none
      [ 0.467078] vgaarb: loaded
      [ 0.467956] SCSI subsystem initialized
      [ 0.468153] libata version 3.00 loaded.
      [ 0.468366] usbcore: registered new interface driver usbfs
      [ 0.468417] usbcore: registered new interface driver hub
      [ 0.468547] usbcore: registered new device driver usb
      [ 0.469598] wmi: Mapper loaded
      [ 0.469607] PCI: Using ACPI for IRQ routing
      [ 0.469616] PCI: pci_cache_line_size set to 64 bytes
      [ 0.469773] reserve RAM buffer: 000000000009f000 - 000000000009ffff
      [ 0.469782] reserve RAM buffer: 000000007f6c1400 - 000000007fffffff
      [ 0.470142] NetLabel: Initializing
      [ 0.470150] NetLabel: domain hash size = 128
      [ 0.470155] NetLabel: protocols = UNLABELED CIPSOv4
      [ 0.470192] NetLabel: unlabeled traffic allowed by default
      [ 0.470345] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
      [ 0.470361] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
      [ 0.470376] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
      [ 0.480211] Switching to clocksource hpet
      [ 0.483551] Switched to NOHz mode on CPU #0
      [ 0.483660] Switched to NOHz mode on CPU #1
      [ 0.503809] AppArmor: AppArmor Filesystem Enabled
      [ 0.503892] pnp: PnP ACPI init
      [ 0.503949] ACPI: bus type pnp registered
      [ 0.536413] pnp 00:00: [bus 00-ff]
      [ 0.536426] pnp 00:00: [io 0x0000-0x0cf7 window]
      [ 0.536435] pnp 00:00: [io 0x0cf8-0x0cff]
      [ 0.536444] pnp 00:00: [io 0x0d00-0xffff window]
      [ 0.536460] pnp 00:00: [mem 0x000a0000-0x000bffff window]
      [ 0.536469] pnp 00:00: [mem 0x000d0000-0x000dffff window]
      [ 0.536479] pnp 00:00: [mem 0x80000000-0xf7ffffff window]
      [ 0.536488] pnp 00:00: [mem 0xfc000000-0xfebfffff window]
      [ 0.536496] pnp 00:00: [mem 0xfec10000-0xfecfffff window]
      [ 0.536505] pnp 00:00: [mem 0xfed1c000-0xfed1ffff window]
      [ 0.536514] pnp 00:00: [mem 0xfed90000-0xfed9ffff window]
      [ 0.536524] pnp 00:00: [mem 0xfeda7000-0xfedfffff window]
      [ 0.536534] pnp 00:00: [mem 0xfee10000-0xff9fffff window]
      [ 0.536543] pnp 00:00: [mem 0xffc00000-0xffdfffff window]
      [ 0.536776] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
      [ 0.536878] pnp 00:01: [irq 12]
      [ 0.536981] pnp 00:01: Plug and Play ACPI device, IDs PNP0f13 (active)
      [ 0.537056] pnp 00:02: [io 0x0060]
      [ 0.537065] pnp 00:02: [io 0x0064]
      [ 0.537072] pnp 00:02: [io 0x0062]
      [ 0.537079] pnp 00:02: [io 0x0066]
      [ 0.537095] pnp 00:02: [irq 1]
      [ 0.537190] pnp 00:02: Plug and Play ACPI device, IDs PNP0303 (active)
      [ 0.537251] pnp 00:03: [io 0x0070-0x0071]
      [ 0.537267] pnp 00:03: [irq 8]
      [ 0.537275] pnp 00:03: [io 0x0072-0x0077]
      [ 0.537371] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
      [ 0.537440] pnp 00:04: [io 0x0061]
      [ 0.537449] pnp 00:04: [io 0x0063]
      [ 0.537455] pnp 00:04: [io 0x0065]
      [ 0.537462] pnp 00:04: [io 0x0067]
      [ 0.537570] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
      [ 0.537645] pnp 00:05: [io 0x002e-0x002f]
      [ 0.537654] pnp 00:05: [io 0x0c80-0x0cff]
      [ 0.537810] system 00:05: [io 0x0c80-0x0cff] could not be reserved
      [ 0.537823] system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active)
      [ 0.537894] pnp 00:06: [dma 4]
      [ 0.537903] pnp 00:06: [io 0x0000-0x000f]
      [ 0.537911] pnp 00:06: [io 0x0080-0x0085]
      [ 0.537919] pnp 00:06: [io 0x0087-0x008f]
      [ 0.537926] pnp 00:06: [io 0x00c0-0x00df]
      [ 0.537934] pnp 00:06: [io 0x0010-0x001f]
      [ 0.537941] pnp 00:06: [io 0x0090-0x0091]
      [ 0.537949] pnp 00:06: [io 0x0093-0x009f]
      [ 0.538050] pnp 00:06: Plug and Play ACPI device, IDs PNP0200 (active)
      [ 0.538110] pnp 00:07: [io 0x00f0-0x00ff]
      [ 0.538132] pnp 00:07: [irq 13]
      [ 0.538234] pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active)
      [ 0.538394] pnp 00:08: [mem 0xfed00000-0xfed003ff]
      [ 0.538567] system 00:08: [mem 0xfed00000-0xfed003ff] has been reserved
      [ 0.538581] system 00:08: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
      [ 0.538902] pnp 00:09: [io 0x0900-0x092f]
      [ 0.538911] pnp 00:09: [io 0x0931-0x0933]
      [ 0.538919] pnp 00:09: [io 0x0935-0x097f]
      [ 0.538927] pnp 00:09: [io 0x0092]
      [ 0.538934] pnp 00:09: [io 0x00b2-0x00b3]
      [ 0.538942] pnp 00:09: [io 0x0020-0x0021]
      [ 0.538950] pnp 00:09: [io 0x00a0-0x00a1]
      [ 0.538958] pnp 00:09: [irq 0 disabled]
      [ 0.538966] pnp 00:09: [io 0x04d0-0x04d1]
      [ 0.538973] pnp 00:09: [io 0x1000-0x1005]
      [ 0.538981] pnp 00:09: [io 0x1008-0x100f]
      [ 0.539029] pnp 00:09: disabling [io 0x1000-0x1005] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
      [ 0.539042] pnp 00:09: disabling [io 0x1008-0x100f] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
      [ 0.539210] system 00:09: [io 0x0900-0x092f] has been reserved
      [ 0.539222] system 00:09: [io 0x0931-0x0933] has been reserved
      [ 0.539233] system 00:09: [io 0x0935-0x097f] has been reserved
      [ 0.539244] system 00:09: [io 0x04d0-0x04d1] has been reserved
      [ 0.539258] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active)
      [ 0.539330] pnp 00:0a: [io 0xf400-0xf4fe]
      [ 0.539338] pnp 00:0a: [io 0x0086]
      [ 0.539346] pnp 00:0a: [io 0x1006-0x1007]
      [ 0.539354] pnp 00:0a: [io 0x100a-0x1059]
      [ 0.539361] pnp 00:0a: [io 0x1060-0x107f]
      [ 0.539369] pnp 00:0a: [io 0x1080-0x10bf]
      [ 0.539377] pnp 00:0a: [io 0x10c0-0x10df]
      [ 0.539385] pnp 00:0a: [io 0x1010-0x102f]
      [ 0.539392] pnp 00:0a: [io 0x0809]
      [ 0.539436] pnp 00:0a: disabling [io 0x1006-0x1007] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
      [ 0.539449] pnp 00:0a: disabling [io 0x100a-0x1059] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
      [ 0.539462] pnp 00:0a: disabling [io 0x1060-0x107f] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
      [ 0.539475] pnp 00:0a: disabling [io 0x1010-0x102f] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
      [ 0.539645] system 00:0a: [io 0xf400-0xf4fe] has been reserved
      [ 0.539656] system 00:0a: [io 0x1080-0x10bf] has been reserved
      [ 0.539666] system 00:0a: [io 0x10c0-0x10df] has been reserved
      [ 0.539676] system 00:0a: [io 0x0809] has been reserved
      [ 0.539688] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
      [ 0.577684] pnp 00:0b: [mem 0x00000000-0x0009efff]
      [ 0.577696] pnp 00:0b: [mem 0x0009f000-0x0009ffff]
      [ 0.577705] pnp 00:0b: [mem 0x000c0000-0x000cffff]
      [ 0.577713] pnp 00:0b: [mem 0x000e0000-0x000fffff]
      [ 0.577722] pnp 00:0b: [mem 0x00100000-0x7f6c13ff]
      [ 0.577730] pnp 00:0b: [mem 0x7f6c1400-0x7f6fffff]
      [ 0.577739] pnp 00:0b: [mem 0x7f700000-0x7f7fffff]
      [ 0.577747] pnp 00:0b: [mem 0xffe00000-0xffffffff]
      [ 0.577762] pnp 00:0b: [mem 0xffa00000-0xffbfffff]
      [ 0.577770] pnp 00:0b: [mem 0xfec00000-0xfec0ffff]
      [ 0.577779] pnp 00:0b: [mem 0xfee00000-0xfee0ffff]
      [ 0.577787] pnp 00:0b: [mem 0xfed20000-0xfed8ffff]
      [ 0.577795] pnp 00:0b: [mem 0xfeda0000-0xfeda3fff]
      [ 0.577803] pnp 00:0b: [mem 0xfeda4000-0xfeda4fff]
      [ 0.577811] pnp 00:0b: [mem 0xfeda5000-0xfeda5fff]
      [ 0.577820] pnp 00:0b: [mem 0xfeda6000-0xfeda6fff]
      [ 0.577828] pnp 00:0b: [mem 0xfed1c800-0xfed1cfff]
      [ 0.577836] pnp 00:0b: [mem 0xfed18000-0xfed1bfff]
      [ 0.577844] pnp 00:0b: [mem 0xf8000000-0xfbffffff]
      [ 0.578166] system 00:0b: [mem 0x00000000-0x0009efff] could not be reserved
      [ 0.578179] system 00:0b: [mem 0x0009f000-0x0009ffff] could not be reserved
      [ 0.578190] system 00:0b: [mem 0x000c0000-0x000cffff] could not be reserved
      [ 0.578201] system 00:0b: [mem 0x000e0000-0x000fffff] could not be reserved
      [ 0.578212] system 00:0b: [mem 0x00100000-0x7f6c13ff] could not be reserved
      [ 0.578223] system 00:0b: [mem 0x7f6c1400-0x7f6fffff] has been reserved
      [ 0.578233] system 00:0b: [mem 0x7f700000-0x7f7fffff] has been reserved
      [ 0.578244] system 00:0b: [mem 0xffe00000-0xffffffff] has been reserved
      [ 0.578255] system 00:0b: [mem 0xffa00000-0xffbfffff] has been reserved
      [ 0.578265] system 00:0b: [mem 0xfec00000-0xfec0ffff] could not be reserved
      [ 0.578276] system 00:0b: [mem 0xfee00000-0xfee0ffff] has been reserved
      [ 0.578287] system 00:0b: [mem 0xfed20000-0xfed8ffff] has been reserved
      [ 0.578297] system 00:0b: [mem 0xfeda0000-0xfeda3fff] has been reserved
      [ 0.578307] system 00:0b: [mem 0xfeda4000-0xfeda4fff] has been reserved
      [ 0.578318] system 00:0b: [mem 0xfeda5000-0xfeda5fff] has been reserved
      [ 0.578329] system 00:0b: [mem 0xfeda6000-0xfeda6fff] has been reserved
      [ 0.578340] system 00:0b: [mem 0xfed1c800-0xfed1cfff] could not be reserved
      [ 0.578351] system 00:0b: [mem 0xfed18000-0xfed1bfff] has been reserved
      [ 0.578362] system 00:0b: [mem 0xf8000000-0xfbffffff] has been reserved
      [ 0.578376] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
      [ 0.578530] pnp: PnP ACPI: found 12 devices
      [ 0.578538] ACPI: ACPI bus type pnp unregistered
      [ 0.578547] PnPBIOS: Disabled by ACPI PNP
      [ 0.620732] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff]
      [ 0.620750] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
      [ 0.620766] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref]
      [ 0.620782] pci 0000:00:1c.3: BAR 15: assigned [mem 0x80600000-0x807fffff 64bit pref]
      [ 0.620797] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
      [ 0.620810] pci 0000:00:1c.1: BAR 13: assigned [io 0x3000-0x3fff]
      [ 0.620823] pci 0000:00:1c.3: BAR 13: assigned [io 0x4000-0x4fff]
      [ 0.620832] pci 0000:00:1c.0: PCI bridge to [bus 0b-0b]
      [ 0.620843] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
      [ 0.620857] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff]
      [ 0.620871] pci 0000:00:1c.0: bridge window [mem 0x80200000-0x803fffff 64bit pref]
      [ 0.620888] pci 0000:00:1c.1: PCI bridge to [bus 0c-0c]
      [ 0.620898] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff]
      [ 0.620912] pci 0000:00:1c.1: bridge window [mem 0xf6d00000-0xf6dfffff]
      [ 0.620925] pci 0000:00:1c.1: bridge window [mem 0x80400000-0x805fffff 64bit pref]
      [ 0.620942] pci 0000:00:1c.3: PCI bridge to [bus 09-09]
      [ 0.620952] pci 0000:00:1c.3: bridge window [io 0x4000-0x4fff]
      [ 0.620966] pci 0000:00:1c.3: bridge window [mem 0xf6c00000-0xf6cfffff]
      [ 0.620979] pci 0000:00:1c.3: bridge window [mem 0x80600000-0x807fffff 64bit pref]
      [ 0.620996] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
      [ 0.621003] pci 0000:00:1e.0: bridge window [io disabled]
      [ 0.621016] pci 0000:00:1e.0: bridge window [mem disabled]
      [ 0.621026] pci 0000:00:1e.0: bridge window [mem pref disabled]
      [ 0.621084] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
      [ 0.621099] pci 0000:00:1c.0: setting latency timer to 64
      [ 0.621130] pci 0000:00:1c.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
      [ 0.621142] pci 0000:00:1c.1: setting latency timer to 64
      [ 0.621172] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
      [ 0.621185] pci 0000:00:1c.3: setting latency timer to 64
      [ 0.621203] pci 0000:00:1e.0: setting latency timer to 64
      [ 0.621215] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
      [ 0.621224] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
      [ 0.621233] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
      [ 0.621243] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
      [ 0.621252] pci_bus 0000:00: resource 8 [mem 0x80000000-0xf7ffffff]
      [ 0.621262] pci_bus 0000:00: resource 9 [mem 0xfc000000-0xfebfffff]
      [ 0.621271] pci_bus 0000:00: resource 10 [mem 0xfec10000-0xfecfffff]
      [ 0.621281] pci_bus 0000:00: resource 11 [mem 0xfed1c000-0xfed1ffff]
      [ 0.621290] pci_bus 0000:00: resource 12 [mem 0xfed90000-0xfed9ffff]
      [ 0.621300] pci_bus 0000:00: resource 13 [mem 0xfeda7000-0xfedfffff]
      [ 0.621309] pci_bus 0000:00: resource 14 [mem 0xfee10000-0xff9fffff]
      [ 0.621319] pci_bus 0000:00: resource 15 [mem 0xffc00000-0xffdfffff]
      [ 0.621328] pci_bus 0000:0b: resource 0 [io 0x2000-0x2fff]
      [ 0.621337] pci_bus 0000:0b: resource 1 [mem 0x80000000-0x801fffff]
      [ 0.621347] pci_bus 0000:0b: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
      [ 0.621356] pci_bus 0000:0c: resource 0 [io 0x3000-0x3fff]
      [ 0.621365] pci_bus 0000:0c: resource 1 [mem 0xf6d00000-0xf6dfffff]
      [ 0.621375] pci_bus 0000:0c: resource 2 [mem 0x80400000-0x805fffff 64bit pref]
      [ 0.621384] pci_bus 0000:09: resource 0 [io 0x4000-0x4fff]
      [ 0.621394] pci_bus 0000:09: resource 1 [mem 0xf6c00000-0xf6cfffff]
      [ 0.621404] pci_bus 0000:09: resource 2 [mem 0x80600000-0x807fffff 64bit pref]
      [ 0.621414] pci_bus 0000:02: resource 4 [io 0x0000-0x0cf7]
      [ 0.621424] pci_bus 0000:02: resource 5 [io 0x0d00-0xffff]
      [ 0.621433] pci_bus 0000:02: resource 6 [mem 0x000a0000-0x000bffff]
      [ 0.621443] pci_bus 0000:02: resource 7 [mem 0x000d0000-0x000dffff]
      [ 0.621453] pci_bus 0000:02: resource 8 [mem 0x80000000-0xf7ffffff]
      [ 0.621464] pci_bus 0000:02: resource 9 [mem 0xfc000000-0xfebfffff]
      [ 0.621474] pci_bus 0000:02: resource 10 [mem 0xfec10000-0xfecfffff]
      [ 0.621484] pci_bus 0000:02: resource 11 [mem 0xfed1c000-0xfed1ffff]
      [ 0.621493] pci_bus 0000:02: resource 12 [mem 0xfed90000-0xfed9ffff]
      [ 0.621503] pci_bus 0000:02: resource 13 [mem 0xfeda7000-0xfedfffff]
      [ 0.621512] pci_bus 0000:02: resource 14 [mem 0xfee10000-0xff9fffff]
      [ 0.621522] pci_bus 0000:02: resource 15 [mem 0xffc00000-0xffdfffff]
      [ 0.621661] NET: Registered protocol family 2
      [ 0.621863] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
      [ 0.622728] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
      [ 0.623920] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
      [ 0.624529] TCP: Hash tables configured (established 131072 bind 65536)
      [ 0.624539] TCP reno registered
      [ 0.624558] UDP hash table entries: 512 (order: 2, 16384 bytes)
      [ 0.624583] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
      [ 0.624919] NET: Registered protocol family 1
      [ 0.624981] pci 0000:00:02.0: Boot video device
      [ 0.625193] PCI: CLS 64 bytes, default 64
      [ 0.625923] cpufreq-nforce2: No nForce2 chipset.
      [ 0.626398] audit: initializing netlink socket (disabled)
      [ 0.626426] type=2000 audit(1304344619.620:1): initialized
      [ 0.651396] highmem bounce pool size: 64 pages
      [ 0.651414] HugeTLB registered 4 MB page size, pre-allocated 0 pages
      [ 0.658518] VFS: Disk quotas dquot_6.5.2
      [ 0.658745] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [ 0.661476] fuse init (API version 7.16)
      [ 0.661865] msgmni has been set to 1668
      [ 0.662743] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
      [ 0.662884] io scheduler noop registered
      [ 0.662891] io scheduler deadline registered
      [ 0.662967] io scheduler cfq registered (default)
      [ 0.663338] pcieport 0000:00:1c.0: setting latency timer to 64
      [ 0.663437] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
      [ 0.663613] pcieport 0000:00:1c.1: setting latency timer to 64
      [ 0.663704] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
      [ 0.663876] pcieport 0000:00:1c.3: setting latency timer to 64
      [ 0.663962] pcieport 0000:00:1c.3: irq 42 for MSI/MSI-X
      [ 0.664287] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
      [ 0.664390] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
      [ 0.664593] intel_idle: MWAIT substates: 0x20220
      [ 0.664612] intel_idle: v0.4 model 0x1C
      [ 0.664618] intel_idle: lapic_timer_reliable_states 0x2
      [ 0.664638] Marking TSC unstable due to TSC halts in idle states deeper than C2
      [ 0.664909] ACPI: Deprecated procfs I/F for AC is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
      [ 0.665097] ACPI: AC Adapter [AC] (on-line)
      [ 0.665506] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input0
      [ 0.724072] ACPI: Lid Switch [LID]
      [ 0.724305] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1
      [ 0.788071] ACPI: Power Button [PBTN]
      [ 0.788293] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input2
      [ 0.788310] ACPI: Sleep Button [SBTN]
      [ 0.788941] ACPI: acpi_idle yielding to intel_idle
      [ 0.801318] thermal LNXTHERM:00: registered as thermal_zone0
      [ 0.801330] ACPI: Thermal Zone [THM] (33 C)
      [ 0.801445] ACPI: Deprecated procfs I/F for battery is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
      [ 0.801625] ERST: Table is not found!
      [ 0.801932] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
      [ 0.802756] isapnp: Scanning for PnP cards...
      [ 0.918949] ACPI: Battery Slot [BAT0] (battery present)
      [ 1.157162] isapnp: No Plug & Play device found
      [ 1.261336] Freeing initrd memory: 17756k freed
      [ 1.292533] Linux agpgart interface v0.103
      [ 1.292700] agpgart-intel 0000:00:00.0: Intel 945GME Chipset
      [ 1.292858] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
      [ 1.293047] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
      [ 1.293293] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
      [ 1.296679] brd: module loaded
      [ 1.298274] loop: module loaded
      [ 1.298547] i2c-core: driver [adp5520] using legacy suspend method
      [ 1.298553] i2c-core: driver [adp5520] using legacy resume method
      [ 1.299812] Fixed MDIO Bus: probed
      [ 1.299922] PPP generic driver version 2.4.2
      [ 1.300087] tun: Universal TUN/TAP device driver, 1.6
      [ 1.300093] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
      [ 1.300328] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [ 1.300402] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 20 (level, low) -> IRQ 20
      [ 1.300438] ehci_hcd 0000:00:1d.7: setting latency timer to 64
      [ 1.300447] ehci_hcd 0000:00:1d.7: EHCI Host Controller
      [ 1.300548] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
      [ 1.300661] ehci_hcd 0000:00:1d.7: using broken periodic workaround
      [ 1.300683] ehci_hcd 0000:00:1d.7: debug port 1
      [ 1.304577] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
      [ 1.304611] ehci_hcd 0000:00:1d.7: irq 20, io mem 0xfed1c000
      [ 1.320035] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
      [ 1.320343] hub 1-0:1.0: USB hub found
      [ 1.320355] hub 1-0:1.0: 8 ports detected
      [ 1.320547] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [ 1.320588] uhci_hcd: USB Universal Host Controller Interface driver
      [ 1.320666] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
      [ 1.320683] uhci_hcd 0000:00:1d.0: setting latency timer to 64
      [ 1.320691] uhci_hcd 0000:00:1d.0: UHCI Host Controller
      [ 1.320801] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
      [ 1.320898] uhci_hcd 0000:00:1d.0: irq 20, io base 0x0000bf80
      [ 1.321226] hub 2-0:1.0: USB hub found
      [ 1.321238] hub 2-0:1.0: 2 ports detected
      [ 1.321415] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
      [ 1.321430] uhci_hcd 0000:00:1d.1: setting latency timer to 64
      [ 1.321439] uhci_hcd 0000:00:1d.1: UHCI Host Controller
      [ 1.321541] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
      [ 1.321649] uhci_hcd 0000:00:1d.1: irq 21, io base 0x0000bf60
      [ 1.321972] hub 3-0:1.0: USB hub found
      [ 1.321983] hub 3-0:1.0: 2 ports detected
      [ 1.322151] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
      [ 1.322171] uhci_hcd 0000:00:1d.2: setting latency timer to 64
      [ 1.322178] uhci_hcd 0000:00:1d.2: UHCI Host Controller
      [ 1.322290] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
      [ 1.324118] uhci_hcd 0000:00:1d.2: irq 22, io base 0x0000bf40
      [ 1.324443] hub 4-0:1.0: USB hub found
      [ 1.324455] hub 4-0:1.0: 2 ports detected
      [ 1.324625] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 23 (level, low) -> IRQ 23
      [ 1.324640] uhci_hcd 0000:00:1d.3: setting latency timer to 64
      [ 1.324648] uhci_hcd 0000:00:1d.3: UHCI Host Controller
      [ 1.324765] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
      [ 1.324872] uhci_hcd 0000:00:1d.3: irq 23, io base 0x0000bf20
      [ 1.325196] hub 5-0:1.0: USB hub found
      [ 1.325207] hub 5-0:1.0: 2 ports detected
      [ 1.325504] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
      [ 1.326205] i8042: Warning: Keylock active
      [ 1.329237] serio: i8042 KBD port at 0x60,0x64 irq 1
      [ 1.329257] serio: i8042 AUX port at 0x60,0x64 irq 12
      [ 1.329620] mousedev: PS/2 mouse device common for all mice
      [ 1.330021] rtc_cmos 00:03: RTC can wake from S4
      [ 1.330214] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
      [ 1.330258] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
      [ 1.330547] device-mapper: uevent: version 1.0.3
      [ 1.330793] device-mapper: ioctl: 4.19.1-ioctl (2011-01-07) initialised: dm-devel@redhat.com
      [ 1.330993] device-mapper: multipath: version 1.2.0 loaded
      [ 1.331002] device-mapper: multipath round-robin: version 1.0.0 loaded
      [ 1.331249] EISA: Probing bus 0 at eisa.0
      [ 1.331256] EISA: Cannot allocate resource for mainboard
      [ 1.331263] Cannot allocate resource for EISA slot 1
      [ 1.331269] Cannot allocate resource for EISA slot 2
      [ 1.331275] Cannot allocate resource for EISA slot 3
      [ 1.331280] Cannot allocate resource for EISA slot 4
      [ 1.331286] Cannot allocate resource for EISA slot 5
      [ 1.331291] Cannot allocate resource for EISA slot 6
      [ 1.331297] Cannot allocate resource for EISA slot 7
      [ 1.331303] Cannot allocate resource for EISA slot 8
      [ 1.331307] EISA: Detected 0 cards.
      [ 1.331644] cpuidle: using governor ladder
      [ 1.331932] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
      [ 1.332113] cpuidle: using governor menu
      [ 1.332963] TCP cubic registered
      [ 1.333431] NET: Registered protocol family 10
      [ 1.334882] NET: Registered protocol family 17
      [ 1.334937] Registering the dns_resolver key type
      [ 1.340688] Using IPI No-Shortcut mode
      [ 1.340990] PM: Hibernation image not present or could not be loaded.
      [ 1.341016] registered taskstats version 1
      [ 1.341484] Magic number: 11:961:987
      [ 1.341636] rtc_cmos 00:03: setting system clock to 2011-05-02 13:57:01 UTC (1304344621)
      [ 1.341646] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
      [ 1.341651] EDD information not available.
      [ 1.341877] Freeing unused kernel memory: 700k freed
      [ 1.342415] Write protecting the kernel text: 5192k
      [ 1.342508] Write protecting the kernel read-only data: 2148k
      [ 1.406911] <30>udev[66]: starting version 167
      [ 1.632072] usb 1-4: new high speed USB device using ehci_hcd and address 2
      [ 1.697422] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/LNXVIDEO:00/input/input4
      [ 1.697612] ACPI: Video Device [VID] (multi-head: yes rom: no post: no)
      [ 1.697665] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
      [ 1.778475] tg3.c:v3.116 (December 3, 2010)
      [ 1.778516] tg3 0000:09:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
      [ 1.778539] tg3 0000:09:00.0: setting latency timer to 64
      [ 1.846913] ahci 0000:00:1f.2: version 3.0
      [ 1.846948] ahci 0000:00:1f.2: PCI INT D -> GSI 19 (level, low) -> IRQ 19
      [ 1.847066] ahci 0000:00:1f.2: irq 43 for MSI/MSI-X
      [ 1.847156] ahci: SSS flag set, parallel bus scan disabled
      [ 1.847213] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 4 ports 1.5 Gbps 0x1 impl SATA mode
      [ 1.847227] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part
      [ 1.847241] ahci 0000:00:1f.2: setting latency timer to 64
      [ 1.861739] tg3 0000:09:00.0: eth0: Tigon3 [partno(BCM95764m) rev 5784100] (PCI Express) MAC address 00:26:b9:04:9d:af
      [ 1.861754] tg3 0000:09:00.0: eth0: attached PHY is 5784 (10/100/1000Base-T Ethernet) (WireSpeed[1])
      [ 1.861766] tg3 0000:09:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
      [ 1.861777] tg3 0000:09:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
      [ 1.865903] b43-pci-bridge 0000:0c:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
      [ 1.865929] b43-pci-bridge 0000:0c:00.0: setting latency timer to 64
      [ 1.928125] usb 1-5: new high speed USB device using ehci_hcd and address 3
      [ 1.928206] scsi0 : ahci
      [ 1.929320] [drm] Initialized drm 1.1.0 20060810
      [ 1.932120] scsi1 : ahci
      [ 1.936104] scsi2 : ahci
      [ 1.940433] ssb: Core 0 found: ChipCommon (cc 0x800, rev 0x16, vendor 0x4243)
      [ 1.940453] ssb: Core 1 found: IEEE 802.11 (cc 0x812, rev 0x0F, vendor 0x4243)
      [ 1.940471] ssb: Core 2 found: PCMCIA (cc 0x80D, rev 0x0A, vendor 0x4243)
      [ 1.940488] ssb: Core 3 found: PCI-E (cc 0x820, rev 0x09, vendor 0x4243)
      [ 1.940546] scsi3 : ahci
      [ 1.941080] ata1: SATA max UDMA/133 abar m1024@0xfed1c800 port 0xfed1c900 irq 43
      [ 1.941091] ata2: DUMMY
      [ 1.941097] ata3: DUMMY
      [ 1.941103] ata4: DUMMY
      [ 2.001474] ssb: Sonics Silicon Backplane found on PCI device 0000:0c:00.0
      [ 2.008782] usbcore: registered new interface driver uas
      [ 2.264172] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
      [ 2.308664] ata1.00: ATA-8: WDC WD1600BEVT-75ZCT2, 11.01A11, max UDMA/133
      [ 2.308673] ata1.00: 312581808 sectors, multi 8: LBA48 NCQ (depth 31/32), AA
      [ 2.310175] ata1.00: configured for UDMA/133
      [ 2.310504] scsi 0:0:0:0: Direct-Access ATA WDC WD1600BEVT-7 11.0 PQ: 0 ANSI: 5
      [ 2.311119] sd 0:0:0:0: Attached scsi generic sg0 type 0
      [ 2.311149] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
      [ 2.311395] sd 0:0:0:0: [sda] Write Protect is off
      [ 2.311407] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
      [ 2.311528] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
      [ 2.335856] sda: sda1 sda4 < sda5 sda6 >
      [ 2.336997] sd 0:0:0:0: [sda] Attached SCSI disk
      [ 2.385475] Initializing USB Mass Storage driver...
      [ 2.396369] scsi4 : usb-storage 1-4:1.0
      [ 2.397944] usbcore: registered new interface driver usb-storage
      [ 2.397953] USB Mass Storage support registered.
      [ 2.438760] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
      [ 2.438772] i915 0000:00:02.0: setting latency timer to 64
      [ 2.477254] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
      [ 2.477266] [drm] MTRR allocation failed. Graphics performance may suffer.
      [ 2.478869] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
      [ 2.478879] [drm] Driver supports precise vblank timestamp query.
      [ 2.561233] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+memwns=io+mem
      [ 2.561691] [drm] initialized overlay support
      [ 2.628115] usb 4-2: new low speed USB device using uhci_hcd and address 2
      [ 2.815094] Console: switching to colour frame buffer device 128x37
      [ 2.815159] fb0: inteldrmfb frame buffer device
      [ 2.815164] drm: registered panic notifier
      [ 2.815459] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
      [ 3.131540] input: IDEACOM IDC 6680 as /devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/input/input5
      [ 3.132115] generic-usb 0003:1CB6:6680.0001: input,hidraw0: USB HID v1.10 Mouse [IDEACOM IDC 6680] on usb-0000:00:1d.2-2/input0
      [ 3.181906] input: IDEACOM IDC 6680 as /devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.1/input/input6
      [ 3.184095] generic-usb 0003:1CB6:6680.0002: input,hidraw1: USB HID v1.10 Mouse [IDEACOM IDC 6680] on usb-0000:00:1d.2-2/input1
      [ 3.184771] usbcore: registered new interface driver usbhid
      [ 3.184781] usbhid: USB HID core driver
      [ 3.398559] scsi 4:0:0:0: Direct-Access Generic- Multi-Card 1.00 PQ: 0 ANSI: 0 CCS
      [ 3.400359] sd 4:0:0:0: Attached scsi generic sg1 type 0
      [ 3.404880] sd 4:0:0:0: [sdb] Attached SCSI removable disk
      [ 3.443754] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [ 9.244419] <30>udev[334]: starting version 167
      [ 9.330048] Adding 2008088k swap on /dev/sda5. Priority:-1 extents:1 across:2008088k
      [ 9.367977] lp: driver loaded but no devices found
      [ 9.677869] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      [ 10.049657] intel_rng: FWH not detected
      [ 10.085710] leds_ss4200: no LED devices found
      [ 10.321106] type=1400 audit(1304344630.476:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=468 comm="apparmor_parser"
      [ 10.329248] type=1400 audit(1304344630.484:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=468 comm="apparmor_parser"
      [ 10.330056] type=1400 audit(1304344630.484:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=468 comm="apparmor_parser"
      [ 10.726769] Linux video capture interface: v2.00
      [ 11.014216] cfg80211: Calling CRDA to update world regulatory domain
      [ 11.116891] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
      [ 11.117315] uvcvideo: Found UVC 1.00 device Integrated_Webcam_1.3M (0c45:6404)
      [ 11.126300] input: Integrated_Webcam_1.3M as /devices/pci0000:00/0000:00:1d.7/usb1/1-5/1-5:1.0/input/input7
      [ 11.126792] usbcore: registered new interface driver uvcvideo
      [ 11.126801] USB Video Class driver (v1.0.0)
      [ 11.396865] Synaptics Touchpad, model: 1, fw: 7.2, id: 0x1a0b1, caps: 0xd04733/0xa40000/0xa0000
      [ 11.433246] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input8
      [ 11.560896] input: Dell WMI hotkeys as /devices/virtual/input/input9
      [ 11.606598] cfg80211: World regulatory domain updated:
      [ 11.606610] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
      [ 11.606621] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
      [ 11.606632] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
      [ 11.606642] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
      [ 11.606652] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
      [ 11.606662] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
      [ 11.609593] b43-phy0: Broadcom 4312 W
        ifconfig shows the wired port up, which is currently my only option to be able to connect to the web
        eth0 Link encap:Ethernet HWaddr 00:26:b9:XX:XX:XX
        inet addr:192.168.0.7 Bcast:192.168.0.255 Mask:255.255.255.0
        inet6 addr: fe80::226:b9ff:fe04:9daf/64 Scope:Link
        UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
        RX packets:721 errors:0 dropped:0 overruns:0 frame:0
        TX packets:863 errors:0 dropped:0 overruns:0 carrier:0
        collisions:0 txqueuelen:1000
        RX bytes:502600 (502.6 KB) TX bytes:213734 (213.7 KB)
        Interrupt:19
        lo Link encap:Local Loopback
        inet addr:127.0.0.1 Mask:255.0.0.0
        inet6 addr: ::1/128 Scope:Host
        UP LOOPBACK RUNNING MTU:16436 Metric:1
        RX packets:20 errors:0 dropped:0 overruns:0 frame:0
        TX packets:20 errors:0 dropped:0 overruns:0 carrier:0
        collisions:0 txqueuelen:0
        RX bytes:1120 (1.1 KB) TX bytes:1120 (1.1 KB)
          Is your Broadcom listed in additional drivers?
          Read this: https://help.ubuntu.com/community/Wi...Driver/bcm43xx
          Intocabile
            Thanks Spadge, these were the magic bits:
            ~$ sudo apt-get update
            ~$ sudo apt-get install bcmwl-kernel-source
            ~$ sudo modprobe -r b43 ssb wl
            ~$ sudo modprobe wl
              Re: [SOLVED] Dell Latitude 2100 and Wireless B43 not working
              Yay!
              Intocabile
