Problems Booting
    Problems Booting
    After three months without using Kubuntu, I did an update and can no longer boot.
    The system boots okay to the splash screen and then I get a black screen with the words
    ian: login
    I put my login and password. It appears to start booting again but then reverts back to the black screen as sudo. It is as if I am in a terminal and cannot get out of there.
    Any suggestions?
    Re: Problems Booting
    Verify that you actually have enough space left in your root partition. Reboot and at the Grub menu select recovery mode. From the CLI type:
    df -hT
    If your / partition reports at or very near 100% (Use%) then you need to do some house cleaning to regain space.
