Wireless not working after clean install
    I have just installed Kubuntu 10.04 on an IBM ThinkPad A30P.
    512MB RAM, 48GB harddrive, ATI graphics
    Ethernet is working fine
    Wireless is not working - IBM High Rate Wireless LAN Mini-PCI Adapter with Modem (Harris Semiconductor/Intersil Corporation Prism 2.5 Wavelan chipset (rev 01) )
    It is a mini-pci card and you can find some more information here:
    http://www.thinkwiki.org/wiki/IBM_Hi...ter_with_Modem
    On this page, it say that it should work with the orinoco driver...
    I had Linux Mint on this one before the Kubuntu installation, and wireless was working (One year old Mint).
    Is this a known problem? I have tried to find a solution to it, but nobody seems to have an exact way of handling it...
    I do NOT need WPA - for the purpose of this laptop, WEP is good enough.
    Tried installing wicd as I never have gotten the Kubuntu/KDE network configuration to work, but still no luck. I know the wireless network is running (can detect it from a different laptop), the card registers in the system as eth1. The card does not come up as disabled, there is just no detection of networks.
    As far as I can tell, it is using the orinoco driver.
    Any tip on how to fix this?
    And yes, Kubuntu 10.04 actually works ok on this old P3 - 1.2 GHz laptop! :-) It will only be used for some light internet access by guests, no gaming or playing video.
    Regards,
    Oceanwatcher
    Blog: http://www.wisnaes.com/
    Pictures: http://www.oceanwatcher.com/
    Software tips (in Norwegian): http://www.datahverdag.com/
    Re: Wireless not working after clean install
    I believe that unlike earlier versions installing wicd does not remove all the previous networkmanager components so you will need to trawl through synaptic for them.
    http://kubuntuforums.net/forums/inde...opic=3112334.0
      If what Liquidator recommends doesn't help you'll need to post the output from
      ifconfig
      and if that lists a wireless port (connected or not) then
      iwlist (whatever port) scanning
        Wow - this is weird! I had a totally different result yesterday! But at least now the wireless shows up in wicd! How can that be?
        ifconfig
        eth0   Link encap:Ethernet HWaddr 00:d0:59:33:de:eb
             inet6 addr: fe80::2d0:59ff:fe33:deeb/64 Scope:Link
             UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
             RX packets:105 errors:0 dropped:0 overruns:0 frame:0
             TX packets:166 errors:0 dropped:0 overruns:0 carrier:0
             collisions:0 txqueuelen:1000
             RX bytes:41632 (41.6 KB) TX bytes:20430 (20.4 KB)
        lo    Link encap:Local Loopback
             inet addr:127.0.0.1 Mask:255.0.0.0
             inet6 addr: ::1/128 Scope:Host
             UP LOOPBACK RUNNING MTU:16436 Metric:1
             RX packets:40 errors:0 dropped:0 overruns:0 frame:0
             TX packets:40 errors:0 dropped:0 overruns:0 carrier:0
             collisions:0 txqueuelen:0
             RX bytes:2000 (2.0 KB) TX bytes:2000 (2.0 KB)
        lspci
        00:00.0 Host bridge: Intel Corporation 82830 830 Chipset Host Bridge (rev 02)
        00:01.0 PCI bridge: Intel Corporation 82830 830 Chipset AGP Bridge (rev 02)
        00:1d.0 USB Controller: Intel Corporation 82801CA/CAM USB Controller #1 (rev 01)
        00:1d.1 USB Controller: Intel Corporation 82801CA/CAM USB Controller #2 (rev 01)
        00:1d.2 USB Controller: Intel Corporation 82801CA/CAM USB Controller #3 (rev 01)
        00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 41)
        00:1f.0 ISA bridge: Intel Corporation 82801CAM ISA Bridge (LPC) (rev 01)
        00:1f.1 IDE interface: Intel Corporation 82801CAM IDE U100 Controller (rev 01)
        00:1f.3 SMBus: Intel Corporation 82801CA/CAM SMBus Controller (rev 01)
        00:1f.5 Multimedia audio controller: Intel Corporation 82801CA/CAM AC'97 Audio Controller (rev 01)
        00:1f.6 Modem: Intel Corporation 82801CA/CAM AC'97 Modem Controller (rev 01)
        01:00.0 VGA compatible controller: ATI Technologies Inc Radeon Mobility M6 LY
        02:00.0 CardBus bridge: Ricoh Co Ltd RL5c478 (rev a0)
        02:00.1 CardBus bridge: Ricoh Co Ltd RL5c478 (rev a0)
        02:00.2 FireWire (IEEE 1394): Ricoh Co Ltd R5C522 IEEE 1394 Controller
        02:02.0 Network controller: Intersil Corporation Prism 2.5 Wavelan chipset (rev 01)
        02:08.0 Ethernet controller: Intel Corporation 82801CAM (ICH3) PRO/100 VE (LOM) Ethernet Controller (rev 41)
        Regards,
        Oceanwatcher
          Did a general scan:
          iwlist scan
          lo    Interface doesn't support scanning.
          eth0   Interface doesn't support scanning.
          irda0   Interface doesn't support scanning.
          eth1   No scan results
          Not sure what to make of it...
          Regards,
          Oceanwatcher
            Just to make sure I have added all info:
            I had a look at this thread yesterday
            http://ubuntuforums.org/showthread.php?t=505920
            and tried the following series:
            $ sudo modprobe -r orinoco_pci
            $ sudo modprobe -r hostap_pci
            $ sudo modprobe -r prism2_pci
            $ sudo modprobe orinoco_pci
            Regards,
            Oceanwatcher
              ifconfig
              A wireless port is not listed in that output of ifconfig, so your wireless device is not recognized.
              lspci
              [b]02:02.0 Network controller: Intersil Corporation Prism 2.5 Wavelan chipset (rev 01)[/b]
              lspci reads both your prism wireless chip and your ethernet chip bios outputs.
              The http://wireless.kernel.org/en/users/Devices/PCI page lists the following for the Prism 2.5 chip:
              orinoco Intersil Prism 2.5 0x1260 0x3873
              which leads you to this site: http://wireless.kernel.org/en/users/Drivers/orinoco
              Intersil Prism 2.5 orinoco_pci 0x1260 0x3873
              and the driver should be orinoco_pci, but going down farther you see this
              Note that support for Intersil (Prism) devices is being disabled from v2.6.35. The hostap driver should be more capable for these cards.
              So, your Prism 2.5 chip should work with the hostap.ko kernel module:
              sudo modprobe hostap
              Before you do that I'd "rmmod" all of the other wireless drivers you modprobed before and reboot.
              IF hostap works for your chip and you get a connection you can make it permanent by issuing
              sudo depmod -a
                Hmmm.... This is what I get now:
                ifconfig
                     inet addr:192.168.254.170 Bcast:192.168.254.255 Mask:255.255.255.0
                     RX packets:86 errors:0 dropped:0 overruns:0 frame:0
                     TX packets:126 errors:0 dropped:0 overruns:0 carrier:0
                     RX bytes:59176 (59.1 KB) TX bytes:17046 (17.0 KB)
                eth1   Link encap:Ethernet HWaddr 00:20:e0:89:5b:cc
                     inet6 addr: fe80::220:e0ff:fe89:5bcc/64 Scope:Link
                     RX packets:0 errors:0 dropped:0 overruns:0 frame:0
                     TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
                     RX bytes:0 (0.0 B) TX bytes:1336 (1.3 KB)
                iwlist scan
                And now the wireless is gone from the list in wicd. One step back and one step forward? :-)
                So what should I try next.
                Regards,
                Oceanwatcher
                  A wireless device getting configured as "eth1" is something I've seen, on rare occasions, when a wireless driver doesn't work or only partially works. I've never gotten an "eth1" wireless to work. Finding the right driver will result in an "wlan0", or "ath0" or some such designation.
                  I'm assuming that you followed the steps in my last msg by cleaning up your system and using only hostap.ko.
                  Unfortunately, it seems that contrary to the wireless.kernel.org page that driver doesn't work for your chip under the kernel you are using.
                  One solution found was, edited to fit your situation:
                  $ sudo rmmod prism2 prism2_pci hostap hostap_pci orinoco_pci orinoco hermes (or what ever was modprobed before. You can use lsmod to check and make sure all wireless drivers are removed.)
                  In /etc/modprobe.d/blacklist.conf add, as root, the following lines:
                  # This makes sure only orinoco_pci gets loaded for the prism2.5 card
                  blacklist prism2
                  blacklist prism2_pci
                  blacklist hostap
                  blacklist hostap_pci
                  Add to that list any wireless drivers you had to remove after examining the lsmod output.
                  reboot
                  $ sudo modprobe orinoco_pci (which becomes the only wireless module)
                  This makes sure only the orinoco drivers are loaded and there are no conflicts over the hardware, so everything works at boot.
                  As before, if it works use "sudo depmod -a" to make it permanent.
                  If it doesn't replace orinoco_pci with hostap_pci and repeat the process. One of the should work.
