[FIXED] Problem: No audio for most applications but not all
    I'm using the lucid release candidate. I've done 2 installs and experienced the same issue.
    Most applications can't produce any sound but there are a few that do:
    - amarok
    - gwenview (previewing movies)
    - dragon player
    - kde greeting jingle
    - kde systeme settings > multimedia > device preferences > when testing HDA Intel (ALC1200 analog) as output
    - kmplayer when specifying the phonon player instead of the default mplayer player
    Additionally these applications are able to produce sound simultaneously.
    Applications without sound:
    - flash
    - games (chromium, pokerth)
    - wine games
    - smplayer, mplayer, kaffeine, vlc
    Anyone have an idea of how to fix this?
    Cheers,
    Francois
    Re: Problem: No audio for most applications but not all
    Yeah having the same problems here, using 64 bit flash not the one from the repo's not sure if that makes a difference
      Fixed. Just had to move the PCM lever in the sound mixer. So that was easy.
      I wonder why only some apps are affected by that lever though.
      Also does anyone know if there exists a panel sound widget for the mixer like for the kde 3.X series where you had small sound levels directly inside the panel (without having to click on a speaker icon) and could basically change the sound volume in one click?
        Thanks fixed it for me too, strange as I've never had to do that before or on ubuntu
