NetworkManager - do you need it?
    Playing around with systemd-analyze and I noticed NetworkManager was taking almost 11 seconds at boot up. 3-4 times anything else. This is a desktop machine so boot time isn't really a big deal, but hey - time is time - or money or something. Anyway, it occurred to me that since this is a desktop and I don't need or use wifi, what exactly do I need Network Manager for? Nada is the answer. I don't even use dhcp here because NFS is easier using fixed IPs. My server sits comfortably connected with no NM installed as it has no desktop at all. So I switched to systemd-networkd instead, which I only recently learned existed. It was pretty simple for the most part. NOTE I'm using KDEneon but it's based on 18.04 and networking isn't different from Kubuntu.
    This change shaved a full 6 seconds off of my boot time. YMMV.
    Removing NetworkManager:
    Since 18.04 was released, we've gone away from the old ifcfg files and now use something called netplan. My server is configured using systemd-networkd and netplan so I knew where to go next.
    First, I stopped and blocked NetworkManager:
    sudo systemctl stop NetworkManager
    sudo systemctl disable NetworkManager
    sudo systemctl mask NetworkManager
    In /etc/netplan/ was 01-network-manager-all.yaml which contained only this:
    # Let NetworkManager manage all devices on this systemnetwork:
      version: 2
      renderer: NetworkManager
    Not much needed because NetworkManager does the work. I removed that file and replaced it with one similar to my server named 01-netcfg.yaml which contains this:
    network:  version: 2
      renderer: networkd
      ethernets:
        enp0s31f6:
          dhcp4: no
          dhcp6: no
          addresses: [192.168.1.199/23]
          gateway4: 192.168.1.1
          nameservers:
            addresses: [8.8.8.8,8.8.4.4]
    Note that this is a fixed IP and I use googles nameservers. If you want normal DCHP (network assigned IP address) then you want something like this:
    network:  version: 2
      renderer: networkd
      ethernets:
        enp0s31f6:
          dhcp4: yes
    Also note that enp0s31f6 is the name of my ethernet port. Yours will be revealed with by running ifconfig in konsole or in KInfocenter under Network Information > Network Interfaces
    Next, I enabled systemd-networkd:
    sudo systemctl unmask systemd-networkd.service
    sudo systemctl enable systemd-networkd.service
    sudo systemctl start systemd-networkd.service
    And finally, applied the netplan changes
    sudo netplan apply
    and rebooted.
    On reboot, it took 30 or more seconds longer than usual, but booted up. I knew something was up, so I ran systemd-analyze blame again and BOTH networkManager and systemd-networkd launched. I don't know why this happened because as far as I know, the first set of commands above should have prevented it from launching. I threw caution to the wind and purged the NetworkManager packages (3 of them), held my breath (not really) and rebooted.
    This time, I had the fastest boot I'd seen in a long time and I was network connected. Success!
    I just tried it. Switching to systemd-networkd that is.
    I did it after reading the other thread, so I followed the instructions on this page. *
    Well, like osnluvr had, before I had:
    7.202s NetworkManager-wait-online.service
    2.005s dev-sdc2.device
    and after I had:
    5.544s systemd-networkd-wait-online.service
    5.009s NetworkManager-wait-online.service
    1.889s dev-sdc2.device
    So, should I throw caution to the wind and purge the NetworkManager packages (3 of them)? Er... which ones? ;·)
    * The page contains an error: $ sudo systemctl start systems-resolved should (obviously) be: $ sudo systemctl start systemd-resolved
      The history from apt:
      Purge: network-manager-pptp:amd64 (1.2.6-1), plasma-nm:amd64 (4:5.18.4.1-0xneon+18.04+bionic+build54), network-manager:amd64 (1.10.14-0ubuntu2)
      so I purged:
      plasma-nm
      network-manager
      I entered "sudo apt purge network-manager" and the other two were auto-removed at the same time
        Perfect. It did just that.
        network-manager* network-manager-pptp* plasma-nm*
        After which:
        4.951s systemd-networkd-wait-online.service
        1.535s udisks2.service
        1.285s dev-sdc2.device
        1.008s mysql.service
        978ms accounts-daemon.service
        950ms ModemManager.service
        893ms postfix@-.service
          Great. IDK why systemd isn't killing the service like it's supposed to. There must be a step I left out. I was a bit nervous to remove it completely like that, but I could reinstall it if I had to.
            I have NetworkManager running and use it.
            $ systemd-analyze
            Startup finished in 2.726s (kernel) + 8.384s (userspace) = 11.110s
            graphical.target reached after 8.374s in userspace
            Here is my blame listing:
            $ systemd-analyze blame
            6.531s NetworkManager-wait-online.service
            1.624s [COLOR=#ff0000]man-db.service    [/COLOR]
             916ms [COLOR=#ff0000]smartmontools.service[/COLOR]
             689ms systemd-logind.service
             545ms [COLOR=#ff0000]snapper-boot.service   [/COLOR]
             516ms dev-sda1.device
             510ms udisks2.service
             486ms systemd-resolved.service
             482ms upower.service
             459ms networkd-dispatcher.service
             424ms systemd-journald.service
             414ms systemd-timesyncd.service
             413ms logrotate.service
             407ms systemd-machined.service
             383ms accounts-daemon.service
             337ms gpu-manager.service
             303ms systemd-fsck@dev-disk-by\x2duuid-ce2b5741\x2dc01e\x2d4b3d\x2db6ba\x2d401ad7f7fcdf.service
            ...skipping...
              14ms systemd-sysctl.service
              13ms sys-kernel-tracing.mount
              12ms systemd-tmpfiles-setup-dev.service
              12ms plymouth-read-write.service
              11ms blk-availability.service
              10ms systemd-remount-fs.service
              10ms systemd-random-seed.service
              10ms kmod-static-nodes.service
               8ms systemd-backlight@backlight:intel_backlight.service
               8ms systemd-user-sessions.service
               7ms systemd-update-utmp-runlevel.service
               7ms console-setup.service
               5ms home.mount
               5ms ufw.service
               4ms sys-fs-fuse-connections.mount
               4ms sddm.service
               3ms sys-kernel-config.mount
            The ones highlighted in red are those services I've added since my last blame reading gave me a 5.1 sec user space load time.
              Yeah, well, so did we
                I am using DHCP. I used a slightly different method than oshunluvr's. See post #2.
                  Ya, I posted a stupid question and deleted it.
                  I have a Hurricane IPv6 tunnel. I used a systemd unit to create and run it.
                  It would be interesting to see if any conflicts arise.
                  Still contemplating...
                    Unrelated to this post, but I'm amazed how much snap adds to boot time. 16 entries in systemd-analyze blame for a total of 5.60152 seconds.
                      Also, removing NM resulted in 15 other packages to go to "no longer required" status.
                      dns-root-data dnsmasq-base iputils-arping libkf5modemmanagerqt6 libkf5wallet-bin libndp0 libnm0 libopenconnect5 libstoken1 libteamdctl0 libtomcrypt1 libtommath1 ppp pptp-linux qml-module-org-kde-prison
                        I'm not
                        See this post, from Jul 24th...
                        ~$ systemd-analyze blame | head -n 20
                              12.054s NetworkManager-wait-online.service
                               3.683s dev-sdb1.device
                               2.455s systemd-journal-flush.service
                               1.813s dev-loop10.device
                               1.811s dev-loop8.device
                               1.809s dev-loop9.device
                               1.636s dev-loop4.device
                               1.613s dev-loop5.device
                               1.601s dev-loop7.device
                               1.597s dev-loop6.device
                               1.594s dev-loop3.device
                               1.546s dev-loop2.device
                               1.535s dev-loop1.device
                               1.528s dev-loop0.device
                               1.316s snapd.service
                               1.042s udisks2.service
                                546ms systemd-udev-trigger.service
                                478ms NetworkManager.service
                                412ms upower.service
                                383ms networkd-dispatcher.service
                          Yikes. Forgot about those. Add another 2.191 seconds.
                            stuart@office:/var/log/apt$ systemd-analyze blame |grep 'loop\|snap'
                            1.120s snapd.service
                            445ms snap-gnome\x2d3\x2d28\x2d1804-116.mount
                            417ms snap-discord-109.mount
                            415ms snap-core-9066.mount
                            405ms snap-shotcut-64.mount
                            375ms snap-gtk\x2dcommon\x2dthemes-1506.mount
                            363ms snap-core18-1754.mount
                            363ms dev-loop2.device
                            328ms snap-gtk\x2dcommon\x2dthemes-1502.mount
                            327ms snap-discord-108.mount
                            327ms snap-gnome\x2d3\x2d26\x2d1604-98.mount
                            326ms snap-vobsub2srt-19.mount
                            324ms snap-core18-1705.mount
                            295ms dev-loop3.device
                            293ms dev-loop4.device
                            285ms snap-shotcut-61.mount
                            219ms dev-loop0.device
                            173ms dev-loop1.device
                            163ms dev-loop6.device
                            143ms dev-loop7.device
                            130ms snap-core-8935.mount
                            127ms dev-loop5.device
                            113ms dev-loop9.device
                            111ms dev-loop8.device
                            75ms dev-loop11.device
                            71ms dev-loop10.device
                            45ms dev-loop12.device
                            14ms snapd.seeded.service
                            523us snapd.socket
                            7.79252 seconds
                              Indeed. That's why I purged snapd and chromium, disabled the loops, located the mount points of the loops and removed them.
