Under System Settings -> Startup and shutdown -> Autostart I have set it to run a script file (/home/<myuser>/startup.sh) upon "Startup". But it does not get executed.
I'm pretty sure the path is correct. The script behaves nicely if I run it from Konsole. I used the same script as startup under KDE 18.04.
Are there any pitfalls I might be running afoul of? What might I be doing wrong?
Thanks in advance!
Thanks in advance!
