I can't get K3B to write CDRs -- looks like some kind of permissions problem, but I'm at a loss to fix it.
Settings->Configure K3b->Programs->Permissions looks like this
![](https://i.imgur.com/SeNvp7A.png)
Only those 3 programs show up in the permissions pane. I altered the permissions as recommended, but it makes no difference.
If I start k3b as root and choose configure k3b, I get this
My user is already a member of the cdrom group.
Burning, whether as root or as a normal user gives
which of course it doesn't.
I should note that this error is new since I changed the permissions to those shown above. Before that, it bailed with ""cdrecord has no permission to open the device"
Here's the relevant section of the log
Anyone else? Any ideas how to fix? I'm guessng it's permissions.
EDIT: Changed permissions for cdrdao and wodim to 0755, and it works.
In order to give K3b full access to the writer device the current user needs be added to a group cdrom.
The Permission helper that could do this for you was not enabled during build.
Please rebuild the package with the Permission helper enabled or contact your distribution.
cdrecord returned an unknown error (code 255)
Sometimes using TAO writing mode solves this issue
Errno: 5 (Input/output error), write_g1 scsi sendcmd: no error CDB: 2A 00 FF FF CF 24 00 02 A0 00 status: 0x2 (CHECK CONDITION) Sense Bytes: 70 00 03 00 00 00 00 0A 00 00 00 80 0C 00 00 00 Sense Key: 0x3 Medium Error, Segment 0 Sense Code: 0x0C Qual 0x00 (write error) Fru 0x0 Sense flags: Blk 0 (not valid) cmd finished after 13.750s timeout 200s /usr/bin/wodim: Could not write Lead-in. SAO startsec: -12508 Writing lead-in... write CD-Text data: error after 0 bytes Writing time: 13.845s /usr/bin/wodim: fifo had 191 puts and 0 gets. /usr/bin/wodim: fifo was 0 times empty and 0 times full, min fill was 100%. cdrecord command: ----------------------- /usr/bin/wodim -v gracetime=2 dev=/dev/sr0 speed=24 -sao driveropts=burnfree textfile=/tmp/k3b.h18167 -useinfo -audio /tmp/k3b_audio_0_01.inf /tmp/k3b_audio_0_02.inf /tmp/k3b_audio_0_03.inf /tmp/k3b_audio_0_04.inf /tmp/k3b_audio_0_05.inf /tmp/k3b_audio_0_06.inf /tmp/k3b_audio_0_07.inf /tmp/k3b_audio_0_08.inf
