Why has Kubuntu installed apt-xapian-index on my system?
    Today, I updated my Kubuntu 16.04 to see this:
     linux-headers-4.10.0-32 linux-headers-4.10.0-32-generic linux-image-4.10.0-32-generic linux-image-extra-4.10.0-32-generic
     linux-signed-image-4.10.0-32-generic
    Use 'sudo apt autoremove' to remove them.
     [B]apt-xapian-index libxapian-1.3-5 python3-xapian1.3[/B]
     bind9-host dnsutils gstreamer-qapt libbind9-140 libdns-export162 libdns162 libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libisc-export160 libisc160
     libisccc140 libisccfg140 liblwres141 libpython3.5 libpython3.5-minimal libpython3.5-stdlib libqapt3 libqapt3-runtime libxml2 libxml2-utils
     python3.5 python3.5-minimal qapt-batch qapt-deb-installer
    24 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
    Need to get 732 kB/10.4 MB of archives.
    After this operation, 4,950 kB of additional disk space will be used.
    Do you want to continue? [Y/n]
    I don't know why this xapian stuff has made its appearance. All I ran was sudo apt-get update followed by sudo apt-get dist-upgrade!
    AFAIK, baloo doesn't use it.
    To look into this the only way I know,
    $ apt rdepends apt-xapian-index
    apt-xapian-index
    Reverse Depends:
     Recommends: software-center (>= 0.38ubuntu1)
     Depends: muon
     Depends: libqapt3
     Suggests: packagekit-backend-aptcc
     Depends: ubuntu-kylin-software-center
     Suggests: synaptic
     Breaks: python-apt (<< 0.25)
     Depends: packagesearch
     Depends: muon
     Depends: goplay
     Suggests: aptitude
    But muon and libqapt3 were already on my system without needing any "xapian" stuff.
    The reason I'm asking is that this "xapian" stuff is used for indexing (IIRC) and is not particularly resource-friendly.
    Kubuntu 20.04
    Muon package manager, among other non-kubuntu software, needs it for search, etc. It is just a simple index of apt packages/information. I do not know why it was not installed when you installed Muon package manager, but it always has been a dep of Muon, for quite a few years now. it doesn't run every time you update, but it does do so periodically.
    Note that on *buntu systems, package deps listed as "recommends" are usually installed along with those listed as "depends" So here, the packages muon, libqapt3, ubuntu-kylin-software-center, packagesearch, goplay, and Ubuntu's software center all would pull in apt-xapian-index when they are installed.
      @claydoh, thank you for clarifying.
      I did not install muon or take any steps to avoid its installation. Mine is a vanilla installation from the Kubuntu 16.04 iso and I just ran apt policy muon and it came up with
      muon:
      Installed: (none)
      Candidate: 4:5.6.0-0ubuntu1.16.04.1
      Version table:
         4:5.6.0-0ubuntu1.16.04.1 500
            500 http://archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages
         4:5.6.0-0ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
      I remember this xapian stuff bumping up my CPU usage way back in Ubuntu 11.04 (which was my first Linux experience). After that, in 12.10, I switched to Lubuntu which didn't have it. Kubuntu 16.04 is my first look at Kubuntu and so I don't want to turn off anything default provided by the system.
      Kubuntu 20.04
        This update to libqapt would be the cause
        https://launchpad.net/ubuntu/+source...0.2-0ubuntu1.2
        which has just been released to the main archive.
          @acheron, thanks for explaining
          Kubuntu 20.04
