Can't Instal winetricks dotnet20 on 64Bit System
    I am running Precise and need to install wintracks dotnet2.0 but run in to a problem about running a 64 bit system.
    From konsole:
    winetricks dotnet20
    Executing w_do_call dotnet11
    Executing load_dotnet11
    This package does not work on a 64-bit installation
    xplorer4x4@xplorer4x4-MS-7673:~/iso2god_v1.3.6-360h$ winetricks dotnet20
    Executing w_do_call dotnet20
    Executing load_dotnet20
    Executing w_do_call fontfix
    Executing load_fontfix
    Setting Windows version to win2k
    Executing winetricks_early_wine regedit C:\windows\Temp\_dotnet20\set-winver.reg
    Executing mkdir -p /home/xplorer4x4/.cache/winetricks/dotnet20
    Executing unzip -o -q -d /home/xplorer4x4/.wine/dosdevices/c:/windows/syswow64 l_intl.zip
    Executing wine dotnetfx.exe
    fixme:advapiecryptFileA "C:\\users\\xplorer4x4\\Temp\\IXP000.TMP\\" 00000000
    p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
    fixme:advapi:LsaOpenPolicy ((null),0x33f31c,0x00000001,0x33f344) stub
    fixme:advapi:LsaClose (0xcafe) stub
    Note: command 'wine dotnetfx.exe' returned status 26. Aborting.
    It launches the installer for dotnet2.0 but when I click next for the first time I get to the next screen and it says it failed to install since htis is a 64 bit system. How can I fix this?
    OS: Kubuntu 12.10/Windows 8
    CPU: Intel Core i7 2600K
    Motherboard: Gigabyte GA-Z77X-UD5H
    Memory: 2x4GB Corsair Dominator
    Graphics Card: MSI R7770
    Monitor: Dell 2208WFP
    Mouse: Mionix NAOS 5000
    PSU: Corsair 520HX
    Case: Thermaltake Mozart TX
    Cooling: Thermalright TRUE Black Ultra-120 eXtreme CPU Heatsink Rev C
    Hard Drives: 1x180 GB Intel 330 SSD - 1xWD 1 TB Caviar Black - 1xWD 2 TB Caviar Green - 2xWD 3 TB Caviar Green
    This might be worth a try.
    First, issue this command:
    export WINEARCH=win32
    Then try the installation again.
    sigpic
    -- Douglas Adams
      Now I get this error when I try winetricks dotnet20,
      wine cmd.exe /c echo '%ProgramFiles%' returned empty string
      if I do export WINEARCH=win64 I can run winetricks dotnet20 but just go back to the same error as in the OP.
      Update I started a clean wineprefix using export WINEPREFIX=$HOME/.new_wine and tried again, but I still have the same error.
      PSU: Corsair 520HX
