Please read before posting in help the new guy
This is a sticky topic.
    Welcome to KFN. You're about to post in the Help the New Guy forum.
    1) Please include the following information in your posts:
    • The version/release of Kubuntu you are using.
    • Whether Kubuntu is actually installed, or is running "live" from a bootable USB Flash Drive or LiveCD.
    • If Kubuntu is installed, is it the only OS on the PC, or is it installed alongside another OS (Windows or ...) or is it installed in a VM (Virtual Machine)?
    • The version of KDE Plasma installed.
    The first and last item can be obtained by pressing Alt+F2 and typing: About this System and pressing Enter/Return.
    2) Information about your PC:
    • Open a konsole and type: inxi -F --xxx
    If inxi isn't installed (unlikely, but...) then type: sudo apt update && sudo apt install inxi. When installation is completed, run the command above.
    • Copy and paste the output.
    This information saves everyone a lot of time (and possibly wasted effort) when attempting to assist you with your question/inquiry/problem.
    Thank you.
