Over the last week or so I've noticed reduced number of posts to the forums. Have all the problems been solved? People learn how to use search? Or some hidden conspiracy laden reason?
Lack of posts to forums
Could be all the above. Plus a dwindling user base, and/or folks using other forms of community interaction.
We are kinda off on our own little world here, as we have always been separate from any official connection to Kubuntu.
And the forum software *really* needs to be upgraded, or something. Some of it has to be some of the reported wonkiness some are seeing.Last edited by claydoh; Aug 24, 2021, 10:42 AM.
Linuxquestions does as well, I think, and they are far busier than we are, so the version itself may not be the issue, but an upgrade might solve the issues we have with whatever database/php mismatches our server has.
One thing we should do, and what LQ does, is to remove all VBulletin branding/text from the forum, as are probably scanning for terms like "Powered by vBulletin? Version 4.2.5" whenever there is a new exploit found.
Originally posted by Bings View PostOne day we may all ascend to the fediverse "The Kubuntu team uses IRC mainly" ok maybe not.
askubuntu/stack exchange has some traffic as well.
There is still a mailing list of all things, that a very few luddites refuse to leave. Now THAT is a dead zone.
Originally posted by claydoh View PostLinuxquestions does as well, I think, and they are far busier than we are, so the version itself may not be the issue, but an upgrade might solve the issues we have with whatever database/php mismatches our server has.
One thing we should do, and what LQ does, is to remove all VBulletin branding/text from the forum, as are probably scanning for terms like "Powered by vBulletin? Version 4.2.5" whenever there is a new exploit found.Windows no longer obstructs my view.
Our host (Open Source) has purchased a licensed copy of vBulletin 5x. From what I'm able to see, it has been installed on our server. Configuration issues seem to be the major issue he is dealing with.Windows no longer obstructs my view.
Originally posted by Snowhog View Post"Our" problem is essentially with version 4.2.5 of vBulletin. It is incompatible with the higher version of PHP. As such, we are restricted to using PHP 5.6.40. Our OS (Ubuntu 20.04) can't use mySQL less than 8.0. mySQL 8.0 and PHP 5.6.40 don't play nice together. THAT is our problem, and can not be fixed as long as we are on vBulletin 4.2.5 and stay with Ubuntu 20.04. We can't revert to the earlier version of Ubuntu as it is EOL. Moving to vBulletin 5x resolves all of our issues.
Code:$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.1 LTS Release: 20.04 Codename: focal
Code:$ mysql --version mysql Ver 14.14 Distrib 5.7.32, for Linux (x86_64) using EditLine wrapper
To get it working, we install these dependencies:
- libmecab2
- python3-mysqldb
- apache2-dev
Then installed the mysql client and server using deb files from mysql.com. We use the 18.04 mysql version, but it works fine. They updated the URLs recently so dont know them all at the moment. THis is the one for the server.
- https://downloads.mysql.com/archives...8.04_amd64.deb
for those who wish, it's easy to get a paid membership at KFN, $12, $24, ... whatever amount you like, paid on Paypal or through a credit card (processed by PayPal). good for 1 yr; not automatically renewed -- it is only 1 yr, IOW. just a suggestion for those considering it. (go to your Profile, click on left side bar "paid subscription," etc. ...Snowhog handles these, btw)An intellectual says a simple thing in a hard way. An artist says a hard thing in a simple way. Charles Bukowski
Originally posted by claydoh View Postirc=telegram=matrix. [url=https://www.reddit.com/r/Kubuntu//r/Kubuntu[/url] gets more traffic than KFN does, most of the time. And that sub is quiet.
Chat rooms are bad for technical support IMO. Forums are better, they are searchable and indexed by search engines so a lot of the time, you don't even need to post to find your answer. They are also better laid out for reading the info.
Originally posted by Qqmike View Postfor those who wish, it's easy to get a paid membership at KFN, $12, $24, ... whatever amount you like, paid on Paypal or through a credit card (processed by PayPal). good for 1 yr; not automatically renewed -- it is only 1 yr, IOW. just a suggestion for those considering it. (go to your Profile, click on left side bar "paid subscription," etc. ...Snowhog handles these, btw)Windows no longer obstructs my view.
