DISTRIB_RELEASE=20.10
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 39 bits physical, 48 bits virtual
CPU(s): 20
On-line CPU(s) list: 0-19
Thread(s) per core: 2
Core(s) per socket: 10
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 165
Model name: Intel(R) Core(TM) i9-10900 CPU @ 2.80GHz
Stepping: 5
CPU MHz: 800.079
CPU max MHz: 5200.0000
CPU min MHz: 800.0000
BogoMIPS: 5599.85
Virtualization: VT-x
L1d cache: 320 KiB
L1i cache: 320 KiB
L2 cache: 2.5 MiB
L3 cache: 20 MiB
NUMA node0 CPU(s): 0-19
Vulnerability Itlb multihit: KVM: Mitigation: VMX disabled
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabl
ed via prctl and seccomp
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __
user pointer sanitization
Vulnerability Spectre v2: Mitigation; Enhanced IBRS, IBPB conditional
, RSB filling
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep
mtrr pge mca cmov pat pse36 clflush dts ac
pi mmx fxsr sse sse2 ss ht tm pbe syscall n
x pdpe1gb rdtscp lm constant_tsc art arch_p
erfmon pebs bts rep_good nopl xtopology non
stop_tsc cpuid aperfmperf pni pclmulqdq dte
s64 monitor ds_cpl vmx smx est tm2 ssse3 sd
bg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2
apic movbe popcnt tsc_deadline_timer aes xs
ave avx f16c rdrand lahf_lm abm 3dnowprefet
ch cpuid_fault invpcid_single ssbd ibrs ibp
b stibp ibrs_enhanced tpr_shadow vnmi flexp
riority ept vpid ept_ad fsgsbase tsc_adjust
bmi1 avx2 smep bmi2 erms invpcid mpx rdsee
d adx smap clflushopt intel_pt xsaveopt xsa
vec xgetbv1 xsaves dtherm ida arat pln pts
hwp hwp_notify hwp_act_window hwp_epp pku o
spke md_clear flush_l1d arch_capabilities
I'm trying to access my NAS hard drive (DS416j synology disk station) without using the web interface. How do I setup a connection to access it in dolphin? Thanks.
CPU(s): 20
Socket(s): 1
NUMA node(s): 1
CPU family: 6
Model: 165
Stepping: 5
CPU MHz: 800.079
BogoMIPS: 5599.85
L1d cache: 320 KiB
L1i cache: 320 KiB
L2 cache: 2.5 MiB
L3 cache: 20 MiB
, RSB filling
