I started converting to QEMU/KVM from VirtualBox this weekend. I don't have much time with it yet, but thought it was worth starting the conversation.
in QEMU.
VM Conversion: The cli tools to convert the drives worked well but for some reason none of the converted Windows disks will boot. There must be a reason because ALL the linux drives did no problem. I was able to create a new Windows 10 client no problem.
Sharing files and folders: There apparently is a way to directly share a folder but I failed at first attempt on a Windows 10 client. Then I just did a samba connection and that worked well. The failed attempt at the folder resulted in preventing the VM from booting. The log file revealed the fact this that I had deleted the folder without removing it from the VM was the cause and restoring the empty folder allowed me to boot, and then I removed the connection from the VM.
USB drive: I was able to connect a USB stick on the Linux host to the Windows Client without too much trouble.
Biggest gripes so far:
The VM window doesn't close when you "power down" the client. Hopefully just a setting I haven't discovered.
The nice little System Tray menu is partially hiddenon my system because I have my panel on the left rather than top or bottom. This rises to a bug IMO:
There doesn't seem to be a way to scroll through them and the top and bottom VMs are cut off.
I'll have more to say later but so far I like the simple interface. Some things like file and clipboard sharing are more difficult. I want to configure the pass through for the video hardware to see how that works. It seems easy to break the VMs, but I could do that in Vbox too. I suspect some of my difficulties are due to the change in how things are done.
If you're going to try this, you'll want to uninstall the guest editions stuff from the VM either after or before the conversion. I didn't have trouble with either method.
in QEMU.
