Java problem?
    Java problem?
    OK so I got interested in working with "junocam" images (shots of Jupiter) that half to be processed .
    I found a Java applet that will do the first part of assembling the RAW strip images into a set of GRB shots that then get layered on to one another but I cant get it to run.
    the person that made the .jar file said it works as expected on his linux manajro install but is getting the same error as me on a Ubuntu-18.04 VM
    the error is
    vinny@vinny-bonox8:~/Downloads/IMG-proc$ java -jar JunoProcessor.jar
    Error: Could not find or load main class junogui.Main
    Caused by: java.lang.NoClassDefFoundError: javafx/application/Application
    the openjfx is installed as well (and is a requirement) .
    any thoughts?
    May be of help: https://stackoverflow.com/questions/...ain-class-mean
      I see openjfx and libopenjfx-java, are they both required?
      Which openjdk is recommended?
        I got it
        In Ubuntu you have to specify some paths, as described in the third response here
        https://askubuntu.com/questions/1036...ith-openjdk-11
        claydoh@claydoh-ideapad:~/Downloads$ java -jar --module-path /usr/share/openjfx/lib --add-modules=javafx.base,javafx.controls,javafx.fxml,javafx.graphics,javafx.media,javafx.swing,javafx.web  JunoProcessor.jar
          I got it
          [ATTACH=CONFIG]8137[/ATTACH]
          thank you clay ,,,,,that did it
            Goes without say'n, but....
            Make yourself an alias so you don't have type out that LONG-G-G-G command.
              lol yup ,
                first attempt
