Problems installing Howdy through terminal
    Hi there,
    Recently I just installed Kubuntu onto my surface pro. I've been trying to install a program called howdy which allows me to unlock my laptop with my face using the on board IR scanner. However, when I try to install howdy I get the following error:
    Traceback (most recent call last):
    File "/var/lib/dpkg/tmp.ci/preinst", line 54, in <module>
    devices = os.listdir("/dev/v4l/by-path")
    FileNotFoundError: [Errno 2] No such file or directory: '/dev/v4l/by-path'
    dpkg: error processing archive /var/cache/apt/archives/howdy_2.5.1_all.deb (--unpack):
    new howdy package pre-installation script subprocess returned error exit status 1
    Is there anyway I can fix this?
    Thanks
    Which version of Kubuntu did you install?
      How did you install, the specific steps and commands used?
      You may have to report this to the developers, if this is a packaging error.
      https://github.com/boltgolt/howdy/issues/137
