firmware failed to leave lps state
    [SOLVED] firmware failed to leave lps state
    IF, after installing the 6.4+ kernel in order to use the rtw_88x2bu type of wifi chip you get an
    "...firmware failed to leave lps state"
    msg flooding your logs then the solution is this:
    In a Konsole issue
    "sudo touch /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf"
    Open that file with your favorite editor and add the following:
    [connection]
    wifi.powersave = 2
    Save it and reboot. The log messages stop appearing.​
