Cross platform ISO image burner - Etcher
    Found this recently: https://etcher.io
    Since a lot of folks have trouble with burning ISOs might be worth a go.
    Interestingly, the program is in an AppImage container, which was new to me. Easy enough to use though I'd never seen one before. The first time you run it, it asks if you want a desktop icon for it, but @here, it actually added it to the Kmenu instead - in the Lost and Found folder.
    I have tried to make it work with Dolphin or from the terminal by passing it a filename - but it doesn't work. It still makes you manually pick the ISO file. I'll keep trying...
