I have printed thousands of pages on an HP Laser Jet 1022. All worked fine until yesterday. Recently I bought and installed a new HP Color Laser Jet M277dw (an all-in-one printer with automatic duplex printing capability). The installation did not go smoothly, altho my version of HPLIP (3.16.7+repac amd64) exceeds the minimum (3.15.4) needed for that printer. I wound up with 4 entries in the printer list for that new printer. Even with the 4 entries, I got it to print, copy, and scan. I don’t need the fax feature. I even got the automatic duplex unit to work. I thought all was OK at that point.
Then yesterday I encountered a problem with the 1022 printer. I wanted to print a 3-page document with pages 1 and 2 on opposite sides of the same sheet of paper. It printed pages 1 and 3. Then when I reran the page containing page 1 so that page 2 would print on the other side of that sheet of paper, page 2 would not print. Something is amiss with Writer’s print dialog. It will not show the document’s first page; instead it begins by showing the document’s page 2. When I tell it to print page 2 (or page 3), the preview window on the left side of the print dialog goes gray, and the words “No pages” display in that window. When I tell it to print page 1, page 2 displays in the window. I don’t want to print page 1, but if I did, I suspect it would print page 2 (the page displayed in the window).
Have you any idea as to what is going on with Writer and the 1022 printer?
