For months I had been plagued with the instability of my ath9k driver in Precise to stay up. Once it negotiates an IP address from my wifi router it almost immediately drops it and then attempts to reconnect. The time it says up varies between less than 10 seconds to less than 10 minutes, but never more. I have tried all the kernels between 3.2 and 3.9.x with no success.
Someone recommended I try the 3.10 kernel from Liquorix. I added its kernel repository and noticed that the only kernels it had were the 32 and 64 bit versions of 3.11-8 so I installed the 64bit kernel:
3.11-8.dmz.1-liquorix-amd64 #1 ZEN SMP PREEMPT Sun Nov 17 03:04:39 UTC 2013 x86_64 GNU/Linux
BAM! My ath9k connection (AR9642 chip) is now rock solid at 54Mb/s
But, all is not roses. VirutalBox won't run under this kernel and running "vboxdrv setup" does nothing. I only set up my WinXP.vdi because KWheezy came with it pre-installed and I wanted to see how it ran. Smooth as silk. (I still have my Win7 partition, which I visit about once every three months to update Microsoft Security Essentials and all the security updates.)
Also the freezing of the plasma-desktop panel continues. It's an interesting bug because the mouse and keyboard continue to work, and Conky continues to display data. It's just that the panel won't respond to mouse activity. And, when I close an app during the freeze its icon remains in the taskbar. I still have to send the plasma-desktop an "INT" signal to release it and/or activate the panel again.
