I know that this will come as a great relief to many but...I'll not be posting for a while because I'm heading to Florida to dive and "observe" underwater therapy for disabled vets from Iraq and Afghanistan.
So aside from the great sigh of relief, what does this have to do with Kubuntu?
Again, I must mention what Shuttleworth said about Windblows and Ipad /Apple OS being the defacto desktops for the future.
Wellllllllllllllllllll
Two things
a)
The dive centre whereat I trained had, fortuitously, a woman using the pool to be trained herself in a form of ..."aqua chiropracty"....she asked if she could "practice" on me and it was amazing..I do not like chiropracty, but...you the patient is held with "face" out of the water and then put through about an hours worth of "chiropracty" twists and turns only it is not on a table, one is not in pain at any time, there is no "creaking and cracking" of joints.
It is rather like being a "piece of kelp" and "waving in the ocean." Just amazing
Another fellow there has incipient carpel tunnel syndrome and is doing the same worthless therapy that has been done for twenty years, and I know because I watched a close friend doing it and it only made things worse.
The fellow that took this water therapy was almost crying because "I can use my hand!".
Anyhoo....
b) APPARENTLY, apparently, I do not know the details, the thereapies that I will "probably" be observing are completely underwater, using scuba.
Not just "diving" but having these therapies done.
And, they will, apparently, be recorded for doctors to see, using, apparently, an Ipad in a particular case and transmitted to a local boat, which will then retransmit to doctors...elsewhere.
Now the point of this post is......
Apparently the case really "is"..."interactive"...in terms of capturing a video, down to 180 feet.
The adverts, of course, are for "divers" ....the details are scant...
http://www.divenewsnetwork.com/index...l-ipad-housing
But the video shows it all:
http://www.youtube.com/watch?v=O2jzI...ature=youtu.be
NOTICE THE BUTTONS ....pushing certain active parts of the screen, apparently, don't know....
Now, the use of it underwater and to transmit from the water, may be iffy.
I am using the Gopro, which does work using a wifi controller, but the range underwater is VERY IFFY.... because, water attenuates the signal of course...
S0 don't know about this..device...
The developer says that you can transmit "from the boat"..which I think is more reasonable...
But, the big point is that the interface of the ipad is useable using the back of this case...
I posted elsewhere about the possiblity, I threw it out for discussion, of having the plasma active GUI possibly go "several routes"...one with the normal elegant screen and another with kludzy screen but....
an interface that could be adapted to use in this kind of housing....
The whole thing about "underwater therapy" is going, I think, to move VERY fast....
And the whole use of the "pad" to record information about things, like therapies, is going, to...I think, positively explode very quickly.
It does not have to be "underwater"...it can be in a factory enviornment, or a hospital environment, or any other kind of "on land" environment, but...
maybe plasma active, Kubuntu, KDE might at least be able to get on top of the curve....getting "ahead" of it might be too much to ask given the simple numbers of installed IOS on pads...but...it might be done..
Which apparently, Shuttleworth has given up on doing.
just a thought...
but...go ahead and sigh a breath of relief!
woodgoingbubblysmoke
Two things
a)
Anyhoo....
just a thought...
