I had a perfectly wunnerful setup of Precise Kubuntu running and installed Calligula nightly build. It installed ok, and said that to run it, one must shut down and log back in with "project Neon" at the login screen.
It is, indeed, there.
But.... absolutely NO joy, I could not get back into my wunnerful Precise install at all.
So...unless you have a completely disposable install, I'd recommend avoiding the nightly build, the "stable" would probably be ok however.
lol woodalwaysmessingaroundsmoke
