Ok here is the situation.
I have, on my second desktop, my "media stuff".
There is a "folderview" for "home" and a Quick Launcher for FF, Amarok and Streamtuner(2).
I want to listen to a perfectly legal stream from Europe and open stream tuner, find the stream, click it.
VLC pops, there may be other players that pop, and I listen. When I have determined that it is, indeed, the desired stream, I click the record button.
A console pops which gives visual reference, in order, which streams are being ripped and that confirms that the system is functioning.
A minute, or two, later a folder AUTOMAGICALLY appears in the folder view with a folder therein that is properly entitled for the station, and therein are....automagically, the various songs in the stream....
Lets see....so what did I do...
a) I clicked stream tuner.
b) I clicked a station type.
c) I clicked a couple of stations to pick the desired one.
d) I listened.
e) I clicked record.
I worked on other stuff, and went to beddy bye.
f) The next day, I stopped the stream, and copied it to a usb stick so I could listen while driving.
four clicks, and a drag.
What a hassle, what a...... drag!
I mean, how much more dead simple can this stuff be?
Anyone have a similar experience with another app?
woodsmoke
d) I listened.
woodsmoke
