piping gpg into tar, issues in 18.04
    [SOLVED] piping gpg into tar, issues in 18.04
    I used to make encrypted backups of folders on my computer onto my external hard drive using the following command. I understand that it pipes gpg into tar, but I wouldn't be able to give a decent explanation of how it works.
    tar zcf   -   /directory/to/backup  | gpg -c >  path/to/external_hard_drive/fileName.tar.gz.gpg
    I would then enter a password for gpg to use, and then let it run. This worked fine in 14.04, but I recently upgraded to 18.04 and the command does not work anymore. It now returns the following error message. Any help would be appreciated. Thanks!
    tar: Removing leading `/' from member names
    gpg: problem with the agent: Inappropriate ioctl for device
    gpg: error creating passphrase: Operation cancelled
    gpg: symmetric encryption of '[stdin]' failed: Operation cancelled
    tar: -: Wrote only 2048 of 10240 bytes
    tar: Child returned status 141
    tar: Error is not recoverable: exiting now
    I run Kubuntu 18.04 LTS.
    I realized my issue--I was trying to use gpg as root. While Kubuntu 14.04 allowed this, apparently Kubuntu 18.04 does not. After recursively chowning my external hard drive, I can now back up to it using gpg and tar on a non-root account.
