Is it possible to write a script that send a signal containing a dictionary of string and array of bytes?
    Is it possible to write a script that makes the following appear in dbus-monitor?
    signal time=1722266455.487564 sender=:1.581 -> destination=(null destination) serial=3 path=/kcminputrc; interface=org.kde.kconfig.notify; member=ConfigChanged
       array [
          dict entry(
             string "Mouse"
             array [
                array of bytes "cursorTheme"
    PS: I'm trying to implement a script that changes a cursor theme while being capable to run on distros without plasma-apply-cursortheme binary.​ The only workaround I've managed to figure out so far is by setting XCURSOR_THEME and restarting a few apps. If you manage to find a way that doesn't require restarting apps, please let me know.
    Thank you very much.
    gdbus can send ("emit") signals with arbitrary arguments. It's part of glib so I think you'll have it already installed, but if not it's in the package libglib2.0-bin.
    I suggest searching for gdbus examples.
      If you could set this up with some test data and maybe post it to repl.it (or format it better), we might be able to help more
      9apps
        I've actually ended up restarting the apps, setting the XCURSOR_THEME and running the following:
                dbus-send --print-reply --session --type=method_call --dest=org.kde.klauncher /KLauncher org.kde.KLauncher.setLaunchEnv string:XCURSOR_THEME string:"$ThemeToUseForTheCursors" > /dev/null 2>&1
                dbus-send --print-reply --session --type=method_call --dest=org.freedesktop.systemd1 /org/freedesktop/systemd1 org.freedesktop.systemd1.Manager.SetEnvironment array:string:XCURSOR_THEME="$ThemeToUseForTheCursors" > /dev/null 2>&1
                dbus-send --print-reply --session --type=method_call --dest=org.freedesktop.DBus /org/freedesktop/DBus org.freedesktop.DBus.UpdateActivationEnvironment dict:string:string:XCURSOR_THEME,"$ThemeToUseForTheCursors" > /dev/null 2>&1
                printf "Xcursor.theme: %s\n" "$ThemeToUseForTheCursors" | xrdb -merge /proc/self/fd/0
        ​        dbus-send --session --type=signal /KGlobalSettings org.kde.KGlobalSettings.notifyChange int32:5 int32:0 # CursorChanged
        The xrdb -merge is required for the change to take effect once KWin is replaced.
        I'm perfectly OK with restarting the apps, so I did it that way.
