I have a couple questions to help me understand btrfs a little better...
Oshunluvr said:
1) I know how to rename a regular file, but how do I go about renaming a btrfs subvolume like @ and @home?
2) Now if I delete /opt, /srv, and the local directory of /usr/local, then replace them each with a subvolume of the same names, I'm wondering what happens when I have finished installing and booting into a second install.
Will those manually added subvolumes then be instantly available along with their contents in the new install, or does something have to be done to tell the new system to use them instead of the plain directories normally created on install?
Oshunluvr said:
2. Rename the new subvolumes to something unique. Since I installed Kubuntu Quantal Quetzal this way, I changed @ to @12_10 and @home to @12_10home. This paves the way for the next install to take the default subvolume names without wiping out the current install.
