Need help booting from iso via grub
    I want to be able to boot GParted (latest) from grub so I don't have to burn a LiveCD/USB. The following 40_custom file isn't working.
    #!/bin/sh
    exec tail -n +3 $0
    # This file provides an easy way to add custom menu entries.  Simply type the
    # menu entries you want to add after this comment.  Be careful not to change
    # the 'exec tail' line above.
    # menuentry "Name of OS here"{
    #       set root='(hd0,x)'
    #       configfile /boot/grub/grub.cfg
    menuentry "Gparted live" {
          set isofile="/home/paul/Downloads/ISOs/gparted-live-0.22.0-1-amd64.iso"
          loopback loop $isofile
          linux (loop)/live/vmlinuz boot=live config union=aufs noswap noprompt ip=frommedia toram=filesystem.squashfs iso-scan/filename=$isofile
          initrd (loop)/live/initrd.img
    After I select Gparted live from the grub menu, the first error says it cannot find the iso. The set isofile= entry is correct.
    Don't you have to tell it the partition?
    Something like
    [S]loopback loop $isofile[/S]
    loopback loop (hd0,5)$isofile
      This gets me as far as asking about the keyboard map and what language I want, and the video detection, but then it never runs x, so I'm left with a black screen and a blinking underline in the upper left corner.
      menuentry "GParted Live" {
            set isofile="/boot/iso/gparted-live-0.22.0-1-amd64.iso"
            linux (loop)/live/vmlinuz boot=live config union=aufs noswap noprompt vga=788 ip=frommedia toram=filesystem.squashfs findiso=$isofile
      I created the directory /boot/iso (sudo mkdir) and copied the iso (sudo cp) to that directory.
        There may be some ideas and details here:
        http://gparted.org/livehd.php
          https://help.ubuntu.com/community/Grub2/ISOBoot
          I haven't read or tried any of this with GRUB2. Also note the occasional notes if you have UEFI (re efi).
            Thanks, but still a no-go. Still the same results as I noted in post #3.
            I can boot gparted, and it prompts me for language, input, and video parameters. Then, when trying to start X, it fails no matter what resolution or driver I choose.
              You may have also seen and tried this troubleshooting outline,
              http://gparted.org/display-doc.php?n...g-gparted-live
                Thanks Mike, but that's for when you boot from a LiveCD/USB and are at the graphical menu after a successful boot.
                Other posts I've found on the 'Net concerning booting the Gparted iso from your HDD complain too, about x not starting. Haven't found a solution yet.
                  sory @Snowhog ,,,,,,I cant seam to get it to boot past the text setup either with a menu entry or grml-rescueboot ,,,,,,,, started trying yesterday.
                    still no joy ,,,,,,,,tried different recipes for 3hr's
                    the live USB made with dd works well
                    will try the dedicated vfat partition thing with the .zip file tomorrow
