Hi
Here is a "convoluted" problem for people who are intrigued by "multivariate" situations!
I've been fiddling with my Kubuntu desktop install on Oneric and things seem to work fine, got compiz going, got conky going, ... the conky thing being a REAL test of whether the whole plasma desktop will crash etc. even got rid of the "flicker" with the old double buffer thing.
I won't post links to various sites because this will, probably, only be solvable by an experienced hand in Kubuntu/compiz/plasma/conky, you name it.
There is a solution to the "transparency" thing in Kubuntu, and I won't belabour linking for it.
There is also a solution for running compiz and conky.
However, and it may just not be solvable, running conky and compiz there just does not seem to be a way to get conky to have "pseudotransparency" and compiz running together.
For the uninitiated what the pseudotransparency does is not produce "transparency" it "kind of double paints" the background within conky, if the background is not "exactly" right one can see what is being done.
So....the question is, does anyone know of a way to get the whole magilla going at once: Kubuntu plasma/compiz/conky AND pseudotransparency for conky?
Here is the only link that I have found that tries to address all of the issues at once and I have tried various iterations to no avail.
I quite realize that it is for "older Ubuntus" but it has scripts which address use in Kubuntu, Compiz etc.
http://ubuntuforums.org/showthread.php?t=205865
Here is my basic conky script:
# Create own window instead of using desktop (required in nautilus)
own_window yes
own_window_type override
own_window_hints undecorated,below,skip_taskbar
background yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
# fiddle with window
use_spacer right
# Use Xft?
use_xft yes
xftfont DejaVu Sans:size=8
xftalpha 0.8
text_buffer_size 2048
# Update interval in seconds
update_interval 3.0
# Minimum size of text area
# minimum_size 250 5
# Draw shades?
draw_shades no
# Text stuff
draw_outline no # amplifies text if yes
draw_borders no
uppercase no # set to yes if you want all text to be in uppercase
# Stippled borders?
stippled_borders 3
# border margins
border_margin 9
# border width
border_width 10
# Default colors and also border colors, grey90 == #e5e5e5
default_color grey
own_window_colour white
own_window_transparent yes
# Text alignment, other possible values are commented
#alignment top_left
alignment top_right
#alignment bottom_left
#alignment bottom_right
# Gap between borders of screen and text
gap_x 10
gap_y 10
# stuff after 'TEXT' will be formatted on screen
TEXT
$color
${color white}SYSTEM ${hr 2}$color
$nodename $sysname $kernel on $machine
${color white}CPU ${hr 2}$color
${freq}MHz Load: ${loadavg} Temp: ${acpitemp}
$cpubar
${cpugraph 000000 ffffff}
NAME PID CPU% MEM%
${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
${top name 4} ${top pid 4} ${top cpu 4} ${top mem 4}
${color white}MEMORY / DISK ${hr 2}$color
RAM: $memperc% ${membar 6}$color
Swap: $swapperc% ${swapbar 6}$color
Root: ${fs_free_perc /}% ${fs_bar 6 /}$color
hda1: ${fs_free_perc /media/sda1}% ${fs_bar 6 /media/sda1}$color
any suggestions would be helpful, I think that if this could be accomplished, it might be an attraction for new migrants from Unity.
And....hint hint....I can think of ONE person who just "might" already have it all done and just didn't think it important enough to post.
woodsmoke
own_window yes
background yes
double_buffer yes
use_spacer right
# Use Xft?
use_xft yes
xftalpha 0.8
update_interval 3.0
# Draw shades?
draw_shades no
# Text stuff
draw_borders no
# Stippled borders?
stippled_borders 3
# border margins
border_margin 9
# border width
border_width 10
default_color grey
#alignment top_left
alignment top_right
gap_x 10
gap_y 10
TEXT
$color
$cpubar
NAME PID CPU% MEM%
woodsmoke
