Hi All,
this is maybe a bit specific, but I spent some time figuring this out and I want to spare others the effort.
So for everyone who is using the NetCDF data format and would like to take advantage of the optimized Intel compilers (C/C++ and Fortran), which are free for personal use on Linux, here is how I did it.
These instructions are for NetCDF 4.1.3 with HDF-5 1.8.6 and zlib 1.2.5, which we will also install here. I used the Intel Compiler Suite version Composer XE 2011.4.191.
I basically followed the quick build instructions here: http://mailman.unidata.ucar.edu/soft...k-Instructions and here: http://software.intel.com/en-us/arti...l-compilers/#6. The former does not include instructions for Intel compilers; the latter is for Intel compilers, but unfortunately already outdated. Hence this post.
First install zlib with the following compiler settings (very fast). For some strange reason the Intel compiler only builds the static library, so I built the shared lib first using GCC (default settings) and then built (and overwrote) the static lib with the script below.
Then you have to install the HDF-5 library, which takes quite long but is pretty straight forward.
The following script has all the flags and configure options I used:
After zlib and HDF-5 are installed you can proceed with the NetCDF library. If you want OPeNDAP support, make sure some version of libcurl is installed on your system (package libcurl3 on ubuntu; you can use the package manager to install it).
I used the script below to build and install NetCDF. There is again a catch with the shared libraries: you need to build the shared libraries first with
and then the static libraries with
. Adapt the configure-options to you needs (I chose /usr/local/ as the installation directory; the default is where you built it...).
With this you should be able to install and use the NetCDF library. Theoretically you can just run these scripts as root and it should work; you only have to edit the settings for static and shared libs (and hence run the netcdf script twice). I hope this saves someone a bit of work... if anyone has comments or has a better way of dealing with these static/shared lib issue, please post a comment.
I'm not an expert with Intel compilers and would like to learn more myself.
(Btw. I tried to post on the Intel forums but the registration did not work.)
Chopstick
#!/bin/bash # script to building zlib-1.2.5 with the Intel Compiler Suite ## load compiler settings # Intel(R) Composer XE 2011 Update 4 for Linux source /opt/intel/composerxe-2011.4.191/bin/compilervars.sh intel64 # compiler suite source /opt/intel/mkl/bin/mklvars.sh intel64 # math kernel library # set environment variables export CC=icc export CPP=icpc export CFLAGS='-O3 -xHost -fPIC' # Note: the Intel compiler can for unknown reasons only build the # static library (libz.a). I built and installed the shared # library with GCC first. #export SFLAGS='-O3 -xHost -fPIC -DPIC -shared' #export LDSHARED='-lpthread' ## build static library # configure ./configure # build and test build make # install library if test successful make check && make install
#!/bin/bash # script to building HDF-1.8.6 with the Intel Compiler Suite ## load compiler settings # Intel(R) Composer XE 2011 Update 4 for Linux source /opt/intel/composerxe-2011.4.191/bin/compilervars.sh intel64 # compiler suite source /opt/intel/mkl/bin/mklvars.sh intel64 # math kernel library # set environment variables export CC=icc export F9X=ifort export CXX=icpc export CFLAGS='-O3 -xHost' export FCFLAGS='-O3 -xHost' export CXXFLAGS='-O3 -xHost' ## build static library # configure (with Fortran and C++ libraries) ./configure --prefix=/usr/local --enable-fortran --enable-cxx # build make # install library if test successful make check && make install
FLAGS='-O3 -xHost'
FLAGS='-O3 -xHost -no-prec-div -static'
#!/bin/bash # script to building netcdf-4.1.3 with the Intel Compiler Suite # (requires zlib-1.2.5 and hdf-1.8.6 and some version of libcurl) ## load compiler settings # Intel(R) Composer XE 2011 Update 4 for Linux source /opt/intel/composerxe-2011.4.191/bin/compilervars.sh intel64 # compiler suite source /opt/intel/mkl/bin/mklvars.sh intel64 # math kernel library # set environment variables FLAGS='-O3 -xHost -no-prec-div -static' # -ipo # Note: I believe the shared libraries have to be built with '-O3 -xHost' only # while the static libs can be built with '-O3 -xHost -no-prec-div -static' # Use two iterations to install shared and static libraries separately # C/C++ export CC=icc export CXX=icpc export CFLAGS=$FLAGS export CXXFLAGS=$FLAGS # Fortran export F9X=ifort export F77=ifort export FC=ifort export F90=ifort export FFLAGS=$FLAGS export FCFLAGS=$FLAGS # Pre-Processor export CPP='icc -E' export CXXCPP='icpc -E' # zlib and hdf5 libraries export CPPFLAGS=-I/usr/local/include export LDFLAGS=-L/usr/local/lib export LD_LIBRARY_PATH=/usr/local:$LD_LIBRARY_PATH ## build static library # configure ./configure --prefix=/usr/local --enable-fortran --enable-cxx --enable-shared --enable-static --enable-dap --with-udunits --with-libcf # build make # install library if test successful make check && make install
Chopstick
