I have written a small script that adjusts the CPU scaling frequency depending on core temperatures. Any feedback or comments are appreciated. This script is designed for a quad core system and has to be run as root.
Adrian
#!/bin/bash
# interval time at which script checks for temperature changes and adjusts max. CPU speed
t3="1"
# maximum average temperature before cpu frequency is reduced
temp_max="60"
temp_core_max="65000"
# random variables to keep the script run indefinitely
count2="0"
counttemp="22"
# minimum frequency of your cpu in herz (change this to what you find in your /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq file)
mintemp="2052000"
# minimum frequency of your cpu in herz (change this to what you find in your /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq file)
maxtemp="3078000"
date > /home/adrian/coretemp.log
while [ "$count2" != "$counttemp" ]
do
gov=`cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor`
if [ "$gov" != "ondemand" ]
then
echo "ondemand" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo "ondemand" > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
echo "ondemand" > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor
echo "ondemand" > /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor
fi
# read core temps
temp0=`cat /sys/devices/platform/coretemp.0/temp1_input`
temp1=`cat /sys/devices/platform/coretemp.1/temp1_input`
temp2=`cat /sys/devices/platform/coretemp.2/temp1_input`
temp3=`cat /sys/devices/platform/coretemp.3/temp1_input`
# calculate average core temperature in celsius
temp_avg=$(expr $temp0 + $temp1 + $temp2 + $temp3)
temp_avg=$(expr $temp_avg / "4000")
# reduce maximum CPU speed if either average core temperature ($temp_avg) is exceeded or if any individual core exceeds the temperature specified in $temp_core_max
if [ "$temp_avg" -gt "$temp_max" ] || [ "$temp0" -gt "$temp_core_max" ] || [ "$temp1" -gt "$temp_core_max" ] || [ "$temp2" -gt "$temp_core_max" ] || [ "$temp3" -gt "$temp_core_max" ]
then
echo $mintemp > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo $mintemp > /sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq
echo $mintemp > /sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq
echo $mintemp > /sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq
# write values to log file - change user to your username
echo "Coretemp: $temp0 $temp1 $temp2 $temp3 - avg: $temp_avg - CPU frequency: 2.05 Ghz" >> /home/user/coretemp.log
sleep 1
else
echo $maxtemp > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo $maxtemp > /sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq
echo $maxtemp > /sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq
echo $maxtemp > /sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq
echo "Coretemp: $temp0 $temp1 $temp2 $temp3 - avg: $temp_avg - CPU frequency: 3.08 Ghz" >> /home/user/coretemp.log
fi
# wait for $t3 seconds
sleep $t3
done
exit 0
Adrian
#!/bin/bash
t3="1"
temp_max="60"
count2="0"
counttemp="22"
mintemp="2052000"
maxtemp="3078000"
do
then
fi
# read core temps
then
sleep 1
else
fi
sleep $t3
done
exit 0
