I ran across an article at OMGUbuntu! about CoverGloobus! ....................talk about a BLAST FROM THE PAST!!
It is a "thing" that will display covers, lyrics, tabs, etc about songs that are playing.
There are quite a few "skins" for it at DeviantArt, the default is small, measuring an inch and half by inch and a half on the desktop, but there are larger ones.
The 64 Bit installed ONLY from the linked page, I tried the d/l from Git etc. with no luck. There is a 32 bit. This was on Xenial.
It does not produce a menu item one must use the search function.
It has a scad of players that it will interact with, using a simple drop down menu system, it really does work quite well, but....well.....why? Because the player, such as Clementine, has to be running so...use Clementine GUI unless one just wants a thing on the desktop to watch etc.
Long ago and far away into the future, I used it for listening to the old xmms, and MPD which need(ed) a client, so now it isn't really that much of a whoop for me, but, it does bring back memories.
Hey, maybe it will give someone and impetus to learn about MPD!
woodgoingdownmemorylanesmoke
