exif - help needed to set tag
    [SOLVED] exif - help needed to set tag
    Have just started to use exif the set .jpg tag from the command line.
    I just want to add notes to photos.
    This works:-
    ~$ exif --ifd=EXIF --tag 0x9286 --set-value="wednesdayZ" /home/bill/IMAG0151.jpg
    but produces a new file.
    Is there a way to just modify the the existing file?
    I would...
    I would use the exiftool (package: libimage-exiftool-perl) to edit file metadata from the cli.
    - ExifTool wiki: http://en.wikipedia.org/wiki/ExifTool
    - ExifTool by Phil Harvey: http://www.sno.phy.queensu.ca/~phil/exiftool/
    - Edit image metadata with ExifTool: http://lwn.net/Articles/249461/
    The ExifTool has options to (man exiftool):
             -overwrite_original              Overwrite original by renaming tmp file
             -overwrite_original_in_place     Overwrite original by copying tmp file
             -P          (-preserve)          Preserve date/time of original file
      Hmm, it looks like it doesn't. Have you tried explicitly setting the --output file as the same as the input? (I'm expecting an error message ...)
        (dummy post because the forum complained about posting links on my first post)
          As Wheel Inventor posts, there are two options to edit the existing file using exiftool. Your command to atomically replace the original would be:
          exiftool -overwrite_original -usercomment="wednesdayZ" /home/bill/IMAG0151.jpg
          or to actually modify the existing file (not atomic, and vulnerable to corrupting the file if the process is interrupted):
          exiftool -overwrite_original_in_place -usercomment="wednesdayZ" /home/bill/IMAG0151.jpg
          - Phil
            Thanks Phil - that's exactly what I was looking for.
            And thanks for the other ideas also
            Bill
