Hi
Now that I have a really nice monitor and new computer, I have my old and trusted ViewSonic about to be put on the shelf.
The new card for the computer is the latest and greatest Nvidia and has the DVI plug.
The question I have is this:
I would like to remove the stand from the Viewsonic, turn it up into "portrait mode", put it on some kind of stand and use it as a portrait mode monitor to work on documents.
Which would give me a larger than life 8 x 11 piece of paper on screen.
a) I do not have the "Nvidia drivers" like I have had before. Yes, there is the Nvidia driver thing but it only now has that I can enter script of some kind to have profiles, but there are NO...presets of any kind.
b) I started with the Nouveau driver and went to fglrx with updates driver thinking I might have more options, but no.
c) I've read up on RandR, (rotate and resize) and it is all terminal stuff and what I need is:
d) the ability to either use a switch box or just unplug/plug/unplug the cable between monitors...
e) the ability to switch the driver from the normal landscape mode for the new monitor to portrait for the Viewsonic.
f) after reading a lot I looked in Synaptic and found a GUI called "kde-workspace-randr".
Not much of a description therein, but it was returned for "grandr" which is "grandma's GUI" for just doing very simple things, and all I want to do is... rotate the screen.
g) question: does anyone have experience with this, because I DO NOT want to bork things on this setup........and I have almost NEVER said that before...I've borked a LOT of stuff!
So....comments on kde-workspace-randr GUI for just doing a simple rotate and not borking things?
Thanks ahead of time!
woodreallylikingmynewhardwaresmoke
