Well, I do have audio on my plantronic wireless headset and HDMI output. I get nothing on built in audio however
. They all work in windows so I know the hardware is good. When I look in settings, built-in analog stereo is listed.
When I try test, it reacts as though it is playing the test tones but I hear nothing. Ran alsamixer and turned sound up, still nothing.
Following is my alsoinfo output from https://wiki.ubuntu.com/Audio/AlsaInfo
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.63
!!Script ran on: Sat Apr 26 15:40:37 UTC 2014
!!Linux Distribution
Ubuntu 14.04 LTS \n \l DISTRIB_ID=Ubuntu DISTRIB_DESCRIPTION="Ubuntu 14.04 LTS" NAME="Ubuntu" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 14.04 LTS" HOME_URL="http://www.ubuntu.com/" SUPPORT_URL="http://help.ubuntu.com/" BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
!!DMI Information
Manufacturer: ASUSTeK Computer INC.
Product Name: CM1730/CM1830
Product Version: System Version
Firmware Version: 0801
!!Kernel Information
Kernel release: 3.13.0-24-generic
Operating System: GNU/Linux
Architecture: x86_64
Processor: x86_64
SMP Enabled: Yes
!!ALSA Version
Driver version: k3.13.0-24-generic
Library version: 1.0.27.2
Utilities version: 1.0.27.2
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
saa7134_alsa
snd_usb_audio
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
!!Soundcards recognised by ALSA
0 [SB ]: HDA-Intel - HDA ATI SB
HDA ATI SB at 0xfcff4000 irq 16
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xfe87c000 irq 19
2 [SAA7134 ]: SAA7134 - SAA7134
saa7133[0] at 0xfebff800 irq 21
3 [Audio ]: USB-Audio - Plantronics Wireless Audio
Plantronics Wireless Audio Plantronics Wireless Audio at usb-0000:00:12.0-3, fu
!!PCI Soundcards installed in the system
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA)
01:00.1 Audio device: NVIDIA Corporation GF119 HDMI Audio Controller (rev a1)
04:06.0 Multimedia controller: Philips Semiconductors SAA7131/SAA7133/SAA7135 Video Broadcast Decoder (rev d1)
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:14.2 0403: 1002:4383
Subsystem: 1043:836c
01:00.1 0403: 10de:0e08 (rev a1)
Subsystem: 3842:3619
!!Modprobe options (Sound related)
snd_atiixp_modem: index=-2
snd_intel8x0m: index=-2
snd_via82xx_modem: index=-2
snd_usb_audio: index=-2
snd_usb_caiaq: index=-2
snd_usb_ua101: index=-2
snd_usb_us122l: index=-2
snd_usb_usx2y: index=-2
snd_cmipci: mpu_port=0x330 fm_port=0x388
snd_pcsp: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : 32,32,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N, N,N,N,N,N,N,N
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y, Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),( null),(null),(null),(null),(null),(null),(null),(n ull),(null),(null),(null),(null),(null),(null),(nu ll),(null),(null),(null),(null),(null),(null),(nul l),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),( null),(null),(null),(null),(null),(null),(null),(n ull),(null),(null),(null),(null),(null),(null),(nu ll),(null),(null),(null),(null),(null),(null),(nul l),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),( null),(null),(null),(null),(null),(null),(null),(n ull),(null),(null),(null),(null),(null),(null),(nu ll),(null),(null),(null),(null),(null),(null),(nul l),(null),(null),(null)
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0
single_cmd : N
snoop : Y
enable_msi : -1
power_save : 0
single_cmd : N
snoop : Y
!!Module: saa7134_alsa
debug : 0
enable : 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, 1,1,1,1,1,1,1
index : -2,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
!!Module: snd_usb_audio
autoclock : Y
device_setup : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0
ignore_ctl_error : N
pid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
vid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
!!HDA-Intel Codec information
--startcollapse--
Codec: VIA VT1708S
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x11060397
Subsystem Id: 0x1043836c
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3
Power: setting=D0, actual=D0
GPIO: io=1, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x10 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="VT1708S Analog", type="Audio", device=0
Amp-Out caps: ofs=0x2a, nsteps=0x2a, stepsize=0x05, mute=0
Amp-Out vals: [0x27 0x27]
Converter: stream=8, channel=0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Node 0x11 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x12 [Audio Output] wcaps 0x611: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="VT1708S Digital", type="HDMI", device=3
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Node 0x13 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x0b, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80]
Converter: stream=4, channel=0
SDI-Select: 0
PCM:
rates [0x560]: 44100 48000 96000 192000
formats [0x1]: PCM
Connection: 1
0x17
Node 0x14 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In vals: [0x8b 0x8b]
Converter: stream=0, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x1e
Node 0x15 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
formats [0x1]: PCM
Node 0x16 [Audio Mixer] wcaps 0x20050b: Stereo Amp-In
Control: name="Rear Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=4, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=3, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x17 0x17] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 7
0x10 0x1f 0x1a 0x1b 0x1e 0x1d 0x25
Node 0x17 [Audio Selector] wcaps 0x300501: Stereo
Connection: 6
0x1f 0x1a* 0x1b 0x1e 0x1d 0x16
Node 0x18 [Audio Selector] wcaps 0x30050d: Stereo Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Connection: 1
0x11
Node 0x19 [Pin Complex] wcaps 0x400581: Stereo
Control: name="Line Out Surround Jack", index=0, device=0
Pincap 0x00000014: OUT Detect
Pin Default 0x01011012: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x40: OUT
Unsolicited: tag=03, enabled=1
Connection: 1
0x18
Node 0x1a [Pin Complex] wcaps 0x400581: Stereo
Control: name="Rear Mic Boost Volume", index=0, device=0
Control: name="Rear Mic Jack", index=0, device=0
Pincap 0x00002334: IN OUT Detect
Vref caps: HIZ 50 100
Pin Default 0x01a19036: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x3, Sequence = 0x6
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=06, enabled=1
Connection: 1
0x26
Node 0x1b [Pin Complex] wcaps 0x400581: Stereo
Control: name="Line Jack", index=0, device=0
Pin Default 0x0181303e: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x3, Sequence = 0xe
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=08, enabled=1
Connection: 1
0x18
Node 0x1c [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Control: name="Line Out Front Jack", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=02, enabled=1
Connection: 1
0x16
Node 0x1d [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Control: name="Front Headphone Jack", index=0, device=0
Pincap 0x0000233c: IN OUT HP Detect
Pin Default 0x0221401f: [Jack] HP Out at Ext Front
DefAssociation = 0x1, Sequence = 0xf
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 2
0x16* 0x25
Node 0x1e [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Control: name="Front Mic Jack", index=0, device=0
Pin Default 0x02a19038: [Jack] Mic at Ext Front
DefAssociation = 0x3, Sequence = 0x8
Unsolicited: tag=07, enabled=1
Connection: 2
0x16* 0x25
Node 0x1f [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Pin Default 0x503701f0: [N/A] CD at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x20 [Pin Complex] wcaps 0x400701: Stereo Digital
Control: name="HDMI Phantom Jack", index=0, device=0
Pincap 0x00000010: OUT
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x40: OUT
Connection: 1
0x12
Node 0x21 [Pin Complex] wcaps 0x400701: Stereo Digital
Control: name="SPDIF Phantom Jack", index=0, device=0
Pin Default 0x074521f0: [Jack] SPDIF Out at Ext Rear Panel
Conn = Optical, Color = Grey
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x15
Node 0x22 [Pin Complex] wcaps 0x400581: Stereo
Control: name="Line Out CLFE Jack", index=0, device=0
Pin Default 0x01016011: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x40: OUT
Unsolicited: tag=04, enabled=1
Connection: 1
0x26
Node 0x23 [Pin Complex] wcaps 0x400581: Stereo
Control: name="Line Out Side Jack", index=0, device=0
Pin Default 0x01012014: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Grey
DefAssociation = 0x1, Sequence = 0x4
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 1
0x27
Node 0x24 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
PCM:
formats [0x1]: PCM
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Side Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Selector] wcaps 0x30050d: Stereo Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Connection: 1
0x24
Node 0x27 [Audio Selector] wcaps 0x30050d: Stereo Amp-Out
Control: name="Side Playback Switch", index=0, device=0
Connection: 1
0x25
Codec: Nvidia GPU 1c HDMI/DP
Address: 0
Vendor Id: 0x10de001c
Subsystem Id: 0x38423619
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Control: name="HDMI/DP,pcm=3 Jack", index=0, device=0
Control: name="ELD", index=0, device=3
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin-ctls: 0x00:
Connection: 2
0x08* 0x09
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Control: name="HDMI/DP,pcm=7 Jack", index=0, device=0
Control: name="IEC958 Playback Con Mask", index=1, device=0
Control: name="IEC958 Playback Pro Mask", index=1, device=0
Control: name="IEC958 Playback Default", index=1, device=0
Control: name="IEC958 Playback Switch", index=1, device=0
Control: name="ELD", index=0, device=7
Pin-ctls: 0x00:
Connection: 2
0x08* 0x09
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Connection: 2
0x08* 0x09
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Connection: 2
0x08* 0x09
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Converter: stream=6, channel=0
Digital: Enabled
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
formats [0x5]: PCM AC3
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
--endcollapse--
!!USB Mixer information
--startcollapse--
USB Mixer: usb_id=0x047fd955, ctrlif=0, ctlerr=0
Card: Plantronics Wireless Audio Plantronics Wireless Audio at usb-0000:00:12.0-3, fu
Unit: 2
Control: name="PCM Playback Volume", index=0
Info: id=2, control=2, cmask=0x0, channels=1, type="S16"
Volume: min=-11776, max=-3072, dBmin=-4600, dBmax=-1200
Unit: 2
Control: name="PCM Playback Switch", index=0
Info: id=2, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
Volume: min=0, max=1, dBmin=0, dBmax=0
Unit: 5
Control: name="Mic Capture Volume", index=0
Info: id=5, control=2, cmask=0x0, channels=1, type="S16"
Volume: min=-7168, max=0, dBmin=-2800, dBmax=0
Unit: 5
Control: name="Mic Capture Switch", index=0
Info: id=5, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 6 Apr 26 11:34 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 15 Apr 26 11:34 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 8 Apr 26 11:34 /dev/snd/controlC2
crw-rw----+ 1 root audio 116, 11 Apr 26 11:34 /dev/snd/controlC3
crw-rw----+ 1 root audio 116, 5 Apr 26 11:34 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 14 Apr 26 11:34 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 4 Apr 26 11:36 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 3 Apr 26 11:38 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 2 Apr 26 11:36 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 13 Apr 26 11:38 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 12 Apr 26 11:36 /dev/snd/pcmC1D7p
crw-rw----+ 1 root audio 116, 7 Apr 26 11:36 /dev/snd/pcmC2D0c
crw-rw----+ 1 root audio 116, 10 Apr 26 11:36 /dev/snd/pcmC3D0c
crw-rw----+ 1 root audio 116, 9 Apr 26 11:38 /dev/snd/pcmC3D0p
crw-rw----+ 1 root audio 116, 1 Apr 26 11:34 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Apr 26 11:34 /dev/snd/timer
/dev/snd/by-id:
total 0
drwxr-xr-x 2 root root 60 Apr 26 11:34 .
drwxr-xr-x 4 root root 400 Apr 26 11:34 ..
lrwxrwxrwx 1 root root 12 Apr 26 11:34 usb-Plantronics_Wireless_Audio_Plantronics_Wireless_Au dio-00 -> ../controlC3
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 120 Apr 26 11:34 .
lrwxrwxrwx 1 root root 12 Apr 26 11:34 pci-0000:00:12.0-usb-0:3:1.0 -> ../controlC3
lrwxrwxrwx 1 root root 12 Apr 26 11:34 pci-0000:00:14.2 -> ../controlC0
lrwxrwxrwx 1 root root 12 Apr 26 11:34 pci-0000:01:00.1 -> ../controlC1
lrwxrwxrwx 1 root root 12 Apr 26 11:34 pci-0000:04:06.0 -> ../controlC2
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: VT1708S Analog [VT1708S Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: SB [HDA ATI SB], device 3: VT1708S Digital [VT1708S Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 3: Audio [Plantronics Wireless Audio], device 0: USB Audio [USB Audio]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 2: SAA7134 [SAA7134], device 0: SAA7134 PCM [SAA7134 PCM]
Subdevices: 1/1
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [SB]
Card hw:0 'SB'/'HDA ATI SB at 0xfcff4000 irq 16'
Mixer name : 'VIA VT1708S'
Components : 'HDA:11060397,1043836c,00100000'
Controls : 45
Simple ctrls : 18
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 42
Mono: Playback 39 [93%] [-4.50dB] [off]
Simple mixer control 'Headphone',0
Capabilities: pswitch
Playback channels: Front Left - Front Right
Mono:
Front Left: Playback [off]
Front Right: Playback [off]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 42 [100%] [0.00dB] [off]
Front Right: Playback 42 [100%] [0.00dB] [off]
Simple mixer control 'Front Mic',0
Capabilities: pvolume pswitch cswitch cswitch-joined cswitch-exclusive
Capture exclusive group: 0
Capture channels: Mono
Limits: Playback 0 - 31
Mono: Capture [off]
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Capture channels: Front Left - Front Right
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Simple mixer control 'Center',0
Mono: Playback 42 [100%] [0.00dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
Mono:
Simple mixer control 'Line',0
Mono: Capture [off]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 31
Front Left: Capture 0 [0%] [-16.50dB] [off]
Front Right: Capture 0 [0%] [-16.50dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Dynamic Power-Control',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono: Capture [on]
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
!!-------Mixer controls for card 1 [NVidia]
Card hw:1 'NVidia'/'HDA NVidia at 0xfe87c000 irq 19'
Mixer name : 'Nvidia GPU 1c HDMI/DP'
Components : 'HDA:10de001c,38423619,00100100'
Controls : 14
Simple ctrls : 2
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
!!-------Mixer controls for card 2 [SAA7134]
Card hw:2 'SAA7134'/'saa7133[0] at 0xfebff800 irq 21'
Mixer name : 'SAA7134 Mixer'
Components : ''
Controls : 6
Simple ctrls : 3
Simple mixer control 'Line',1
Capabilities: volume cswitch
Limits: 0 - 20
Front Left: 0 [0%] Capture [on]
Front Right: 0 [0%] Capture [on]
Simple mixer control 'Line',2
Limits: 0 - 20
Front Left: 0 [0%] Capture [off]
Front Right: 0 [0%] Capture [off]
Simple mixer control 'Video',0
Limits: 0 - 20
!!-------Mixer controls for card 3 [Audio]
Card hw:3 'Audio'/'Plantronics Wireless Audio Plantronics Wireless Audio at usb-0000:00:12.0-3, fu'
Mixer name : 'USB Mixer'
Components : 'USB047f:d955'
Controls : 6
Simple ctrls : 2
Limits: Playback 0 - 34
Mono: Playback 21 [62%] [-25.00dB] [on]
Simple mixer control 'Mic',0
Capabilities: cvolume cvolume-joined cswitch cswitch-joined
Limits: Capture 0 - 28
Mono: Capture 27 [96%] [-1.00dB] [on]
!!Alsactl output
--startcollapse--
state.SB {
control.1 {
iface MIXER
name 'Front Playback Volume'
value.0 42
value.1 42
comment {
access 'read write'
type INTEGER
count 2
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Front Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Surround Playback Volume'
value.0 42
value.1 42
comment {
access 'read write'
type INTEGER
count 2
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Surround Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Center Playback Volume'
value 42
comment {
access 'read write'
type INTEGER
count 1
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
control.6 {
iface MIXER
name 'LFE Playback Volume'
value 42
comment {
access 'read write'
type INTEGER
count 1
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
name 'Center Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.8 {
iface MIXER
name 'LFE Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'Side Playback Volume'
value.0 42
value.1 42
comment {
access 'read write'
type INTEGER
count 2
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Side Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.12 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.13 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.14 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.15 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.16 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.17 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.18 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.19 {
iface MIXER
name 'Capture Source'
value 'Rear Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Rear Mic'
item.1 'Front Mic'
item.2 Line
control.20 {
iface MIXER
name 'Capture Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1650
dbmax 3000
dbvalue.0 -1650
dbvalue.1 -1650
control.21 {
iface MIXER
name 'Capture Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.22 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3075
dbvalue.0 0
dbvalue.1 0
control.23 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3075
dbvalue.0 0
dbvalue.1 0
control.24 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000'
comment {
access read
type IEC958
count 1
control.25 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000'
comment {
access read
type IEC958
count 1
control.26 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000'
comment {
access 'read write'
type IEC958
count 1
control.27 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.28 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.29 {
iface MIXER
name 'Master Playback Volume'
value 39
comment {
access 'read write'
type INTEGER
count 1
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 -450
control.30 {
iface MIXER
name 'Master Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.31 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface CARD
name 'Front Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.33 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.34 {
iface CARD
name 'Line Out Front Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.35 {
iface CARD
name 'Line Out Surround Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.36 {
iface CARD
name 'Line Out CLFE Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.37 {
iface CARD
name 'Line Out Side Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface CARD
name 'Front Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.39 {
iface CARD
name 'HDMI Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.40 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.41 {
iface MIXER
name 'Dynamic Power-Control'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.42 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access read
type INTEGER
count 8
range '0 - 36'
control.43 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.44 {
iface PCM
device 3
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.45 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.NVidia {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value '100009006d10000100000000000000005a632872565832373 53320534552494553097f07000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000'
comment {
access 'read volatile'
type BYTES
count 95
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.14 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.SAA7134 {
control.1 {
iface MIXER
name 'Video Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 20'
control.2 {
iface MIXER
name 'Line Volume'
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 20'
control.3 {
iface MIXER
name 'Line Volume'
index 2
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 20'
control.4 {
iface MIXER
name 'Video Capture Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Line Capture Switch'
index 1
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.6 {
iface MIXER
index 2
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
state.Audio {
control.1 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.2 {
iface PCM
value 0
comment {
access read
type INTEGER
count 1
range '0 - 36'
control.3 {
iface MIXER
name 'PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.4 {
iface MIXER
value 21
comment {
access 'read write'
type INTEGER
count 1
range '0 - 34'
dbmin -4600
dbmax -1200
dbvalue.0 -2500
control.5 {
iface MIXER
name 'Mic Capture Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface MIXER
name 'Mic Capture Volume'
value 27
comment {
access 'read write'
type INTEGER
count 1
range '0 - 28'
dbmin -2800
dbmax 0
dbvalue.0 -100
--endcollapse--
!!All Loaded Modules
Module
ipt_MASQUERADE
iptable_nat
nf_nat_ipv4
nf_nat
nf_conntrack_ipv4
nf_defrag_ipv4
xt_conntrack
nf_conntrack
ipt_REJECT
xt_CHECKSUM
iptable_mangle
xt_tcpudp
bridge
stp
llc
ip6table_filter
ip6_tables
iptable_filter
ip_tables
ebtable_nat
ebtables
x_tables
bnep
rfcomm
bluetooth
nls_iso8859_1
dm_crypt
snd_hda_codec_hdmi
snd_usb_audio
snd_usbmidi_lib
joydev
saa7134_alsa
snd_hda_codec_via
snd_hda_intel
snd_hda_codec
snd_seq_midi
snd_seq_midi_event
snd_hwdep
snd_pcm
kvm_amd
kvm
saa7134
snd_rawmidi
tveeprom
videobuf_dma_sg
psmouse
snd_seq
serio_raw
rc_core
v4l2_common
k10temp
snd_page_alloc
videobuf_core
edac_core
videodev
edac_mce_amd
snd_seq_device
snd_timer
sp5100_tco
i2c_piix4
snd
soundcore
asus_atk0110
parport_pc
mac_hid
ppdev
lp
parport
pata_acpi
hid_logitech_dj
hid_generic
usbhid
hid
nouveau
mxm_wmi
video
i2c_algo_bit
ttm
drm_kms_helper
pata_atiixp
r8169
ahci
drm
libahci
mii
sata_sil24
wmi
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x19 0x01011012
0x1a 0x01a19036
0x1b 0x0181303e
0x1c 0x01014010
0x1d 0x0221401f
0x1e 0x02a19038
0x1f 0x503701f0
0x20 0x185600f0
0x21 0x074521f0
0x22 0x01016011
0x23 0x01012014
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x585600f0
0x07 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[ 19.400752] kvm: Nested Paging enabled
[ 19.414391] hda-intel 0000:00:14.2: Using LPIB position fix
[ 19.417863] hda-intel 0000:00:14.2: Enable sync_write for stable communication
[ 19.425954] autoconfig: line_outs=4 (0x1c/0x19/0x22/0x23/0x0) type:line
[ 19.425965] Line=0x1b
[ 19.436330] input: HDA ATI SB Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input15
[ 19.436425] input: HDA ATI SB Line Out Side as /devices/pci0000:00/0000:00:14.2/sound/card0/input14
[ 19.436552] input: HDA ATI SB Line Out CLFE as /devices/pci0000:00/0000:00:14.2/sound/card0/input13
[ 19.436690] input: HDA ATI SB Line Out Surround as /devices/pci0000:00/0000:00:14.2/sound/card0/input12
[ 19.436761] input: HDA ATI SB Line Out Front as /devices/pci0000:00/0000:00:14.2/sound/card0/input11
[ 19.436890] input: HDA ATI SB Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input10
[ 19.436971] input: HDA ATI SB Front Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input9
[ 19.437036] input: HDA ATI SB Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input8
[ 19.437347] hda_intel: Disabling MSI
[ 19.437356] hda-intel 0000:01:00.1: Handle VGA-switcheroo audio client
[ 19.437383] hda-intel 0000:01:00.1: Disabling 64bit DMA
[ 19.441798] hda-intel 0000:01:00.1: Enable delay in RIRB handling
[ 19.448614] type=1400 audit(1398526461.630:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=505 comm="apparmor_parser"
[ 19.541316] saa7133[0]: registered device vbi0
[ 19.543951] saa7134 ALSA driver for DMA sound loaded
[ 19.543975] saa7133[0]/alsa: saa7133[0] at 0xfebff800 irq 21 registered as card -2
[ 19.699346] usbcore: registered new interface driver snd-usb-audio
[ 19.730406] r8169 0000:03:00.0 eth0: link down
[ 19.730431] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.566307] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input17
[ 20.566395] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input16
[ 20.914759] EXT4-fs (sdb2): re-mounted. Opts: errors=remount-ro
Any help appreciated. ubuntu is fresh install, not an update. btw, the built-in sound worked in 12.04 and 13.10
!!DMI Information
Processor: x86_64
SMP Enabled: Yes
!!ALSA Version
snd_hda_intel
snd_hda_intel
saa7134_alsa
snd_usb_audio
Pulseaudio:
Running - Yes
snd_pcsp: index=-2
enable_msi : -1
power_save : 0
single_cmd : N
snoop : Y
enable_msi : -1
power_save : 0
single_cmd : N
snoop : Y
debug : 0
autoclock : Y
--startcollapse--
Codec: VIA VT1708S
Address: 0
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
PCM:
formats [0x1]: PCM
PCM:
formats [0x1]: PCM
Digital:
PCM:
formats [0x1]: PCM
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x17
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x1e
Digital:
PCM:
formats [0x1]: PCM
Connection: 7
Connection: 6
Connection: 1
0x11
Pin-ctls: 0x40: OUT
Connection: 1
0x18
Connection: 1
0x26
Connection: 1
0x18
EAPD 0x2: EAPD
Pin-ctls: 0x40: OUT
Connection: 1
0x16
Connection: 2
0x16* 0x25
Connection: 2
0x16* 0x25
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Pin-ctls: 0x40: OUT
Connection: 1
0x12
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x15
Pin-ctls: 0x40: OUT
Connection: 1
0x26
Pin-ctls: 0x40: OUT
Connection: 1
0x27
PCM:
formats [0x1]: PCM
PCM:
formats [0x1]: PCM
Connection: 1
0x24
Connection: 1
0x25
Address: 0
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Pin-ctls: 0x00:
Connection: 2
0x08* 0x09
Pin-ctls: 0x00:
Connection: 2
0x08* 0x09
Pin-ctls: 0x00:
Connection: 2
0x08* 0x09
Pin-ctls: 0x00:
Connection: 2
0x08* 0x09
Digital: Enabled
PCM:
Digital:
PCM:
--endcollapse--
--startcollapse--
Unit: 2
Unit: 2
Unit: 5
Unit: 5
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-id:
total 0
/dev/snd/by-path:
total 0
APLAY
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
ARECORD
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
!!Amixer output
Controls : 45
Simple ctrls : 18
Mono:
Mono:
Mono:
Mono: Capture [off]
Limits: 0 - 3
Mono:
Mono:
Mono: Capture [off]
Mono: Playback [on]
Capabilities: enum
Item0: 'Enabled'
Capabilities: enum
Item0: 'Disabled'
Mono: Capture [on]
Limits: 0 - 3
Controls : 14
Simple ctrls : 2
Mono: Playback [on]
Mono: Playback [on]
Components : ''
Controls : 6
Simple ctrls : 3
Limits: 0 - 20
Limits: 0 - 20
Limits: 0 - 20
Controls : 6
Simple ctrls : 2
!!Alsactl output
--startcollapse--
state.SB {
control.1 {
iface MIXER
value.0 42
value.1 42
comment {
access 'read write'
type INTEGER
count 2
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
value.0 42
value.1 42
comment {
access 'read write'
type INTEGER
count 2
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
value 42
comment {
access 'read write'
type INTEGER
count 1
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
control.6 {
iface MIXER
value 42
comment {
access 'read write'
type INTEGER
count 1
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.8 {
iface MIXER
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
value.0 42
value.1 42
comment {
access 'read write'
type INTEGER
count 2
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.12 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.13 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.14 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.15 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.16 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.17 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.18 {
iface MIXER
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.19 {
iface MIXER
value 'Rear Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Rear Mic'
item.1 'Front Mic'
item.2 Line
control.20 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1650
dbmax 3000
dbvalue.0 -1650
dbvalue.1 -1650
control.21 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.22 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3075
dbvalue.0 0
dbvalue.1 0
control.23 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3075
dbvalue.0 0
dbvalue.1 0
control.24 {
iface MIXER
comment {
access read
type IEC958
count 1
control.25 {
iface MIXER
comment {
access read
type IEC958
count 1
control.26 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.27 {
iface MIXER
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.28 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.29 {
iface MIXER
value 39
comment {
access 'read write'
type INTEGER
count 1
range '0 - 42'
dbmin -6300
dbmax 0
dbvalue.0 -450
control.30 {
iface MIXER
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.31 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.33 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.34 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.35 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.36 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.37 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.39 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.40 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.41 {
iface MIXER
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.42 {
iface PCM
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access read
type INTEGER
count 8
range '0 - 36'
control.43 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.44 {
iface PCM
device 3
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.45 {
iface MIXER
value.0 255
value.1 255
comment {
type INTEGER
count 2
range '0 - 255'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.NVidia {
control.1 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
comment {
type BYTES
count 95
control.7 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.14 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.SAA7134 {
control.1 {
iface MIXER
name 'Video Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 20'
control.2 {
iface MIXER
name 'Line Volume'
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 20'
control.3 {
iface MIXER
name 'Line Volume'
index 2
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 20'
control.4 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
index 1
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.6 {
iface MIXER
index 2
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
state.Audio {
control.1 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.2 {
iface PCM
value 0
comment {
access read
type INTEGER
count 1
range '0 - 36'
control.3 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.4 {
iface MIXER
value 21
comment {
access 'read write'
type INTEGER
count 1
range '0 - 34'
dbmin -4600
dbmax -1200
dbvalue.0 -2500
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface MIXER
value 27
comment {
access 'read write'
type INTEGER
count 1
range '0 - 28'
dbmin -2800
dbmax 0
dbvalue.0 -100
--endcollapse--
Module
ipt_MASQUERADE
iptable_nat
nf_nat_ipv4
nf_nat
nf_conntrack_ipv4
nf_defrag_ipv4
xt_conntrack
nf_conntrack
ipt_REJECT
xt_CHECKSUM
iptable_mangle
xt_tcpudp
bridge
stp
llc
ip6table_filter
ip6_tables
iptable_filter
ip_tables
ebtable_nat
ebtables
x_tables
bnep
rfcomm
bluetooth
nls_iso8859_1
dm_crypt
snd_hda_codec_hdmi
snd_usb_audio
snd_usbmidi_lib
joydev
saa7134_alsa
snd_hda_codec_via
snd_hda_intel
snd_hda_codec
snd_seq_midi
snd_seq_midi_event
snd_hwdep
snd_pcm
kvm_amd
kvm
saa7134
snd_rawmidi
tveeprom
videobuf_dma_sg
psmouse
snd_seq
serio_raw
rc_core
v4l2_common
k10temp
snd_page_alloc
videobuf_core
edac_core
videodev
edac_mce_amd
snd_seq_device
snd_timer
sp5100_tco
i2c_piix4
snd
soundcore
asus_atk0110
parport_pc
mac_hid
ppdev
lp
parport
pata_acpi
hid_logitech_dj
hid_generic
usbhid
hid
nouveau
mxm_wmi
video
i2c_algo_bit
ttm
drm_kms_helper
pata_atiixp
r8169
ahci
drm
libahci
mii
sata_sil24
wmi
!!Sysfs Files
0x19 0x01011012
0x1a 0x01a19036
0x1b 0x0181303e
0x1c 0x01014010
0x1d 0x0221401f
0x1e 0x02a19038
0x1f 0x503701f0
0x20 0x185600f0
0x21 0x074521f0
0x22 0x01016011
0x23 0x01012014
0x04 0x185600f0
0x05 0x185600f0
0x06 0x585600f0
0x07 0x585600f0
!!ALSA/HDA dmesg
