Perl Audio Converter
Links:
Home: Perl Audio Converter
In the wishlist: Bug #104098 in Ubuntu / needs packaging] Perl Audio Converter - pacpl
Iinstalling perl audio converter (Ubuntu Forums)
Perl Audio Converter (sourceforge)
Latest Release: v4.0.2, My .deb (86 KB): pacpl_4.0.2-1_i386.deb (FileMojo) or REGGLE Download Link or http://rapidshare.com/files/10980223..._i386.deb.html
Installation
Tested with the Kubuntu (7.10) Gutsy Gibbon and Kubuntu (8.04) Hardy Heron.
During installation pacpl might need feedback from the user:
Asks mostly hard questions like:
Note from the README.Debian:
Pacpl is a perl script that will use other programs to do conversion. After installation command:
will tell what programs you need (file attached at the end of the page).
More:
Even more:
Perl Audio Converter has kommander front-end. It will start:
With the Hardy:
and kubuntu-restricted-extras + mplayer => Dolphin (d3lphin) Right click audio file(s) > Actions > PACPL-Convert:
Description:
Perl Audio Converter is a tool for converting multiple audio types from one format to another. It supports AAC, AC3, AIFF, APE, AU, AVR, BONK, CAF, CDR, FAP, FLA, FLAC, IRCAM, LA, LPAC, M4A, MAT, MAT4, MAT5, MMF, MP2, MP3, MP4, MPC, MPP, NIST, OFR, OFS, OGG, PAC, PAF, PVF, RA, RAM, RAW, SD2, SF, SHN, SMP, SND, SPX, TTA, VOC, W64, WAV, WMA, and WV. It can also convert audio from the following video extensions: RM, RV, ASF, DivX, MPG, MKV, MPEG, AVI, MOV, OGM, QT, VCD, SVCD, M4V, NSV, NUV, PSP, SMK, VOB, FLV, and WMV. A CD ripping function with CDDB support, batch conversion, tag preservation for most supported formats, independent tag reading/writing, and extensions for Amarok, Dolphin, and Konqueror are also provided.
Links:
Installation
CPAN is the world-wide archive of perl resources. It consists of about
100 sites that all replicate the same contents all around the globe.
Many countries have at least one CPAN site already. The resources
found on CPAN are easily accessible with the CPAN.pm module. If you
want to use CPAN.pm, you have to configure it properly.
If you do not want to enter a dialog now, you can answer 'no' to this
question and I'll try to autoconfigure. (Note: you can revisit this
dialog anytime later by typing 'o conf init' at the cpan prompt.)
Are you ready for manual configuration? [yes]
First, pick a nearby continent and country (you can pick several of
each, separated by spaces, or none if you just want to keep your
existing selections). Then, you will be presented with a list of URLs
of CPAN mirrors in the countries you selected, along with previously
selected URLs. Select some of those URLs, or just keep the old list.
Finally, you will be prompted for any extra URLs -- file:, ftp:, or
http: -- that host a CPAN mirror.
(1) Africa
(2) Asia
(3) Central America
(4) Europe
(5) North America
(6) Oceania
(7) South America
Select your continent (or several nearby continents) [].
(1) Africa
(2) Asia
(3) Central America
(4) Europe
(5) North America
(6) Oceania
(7) South America
Upon install, pacpl checks for when needed recommended programs are available and only installs support for those that exist. If you add another program later, reinstall pacpl and the menu entries will be added.
-- Chad Martin <chadm@linuxappfinder.com>, Fri, 04 Aug 2006 13:34:00 -0500
pacpl -f
More:
pacpl --help
Perl Audio Converter - 4.0.2
-t, --to destination format
-r, --recursive recursively convert directory(s)
-p, --preserve preserve directory structure
-f, --formats list supported encode/decode formats
-o, --only only convert files matching extension
-k, --keep keep files matching destination format
-h, --help this help menu
-l, --longhelp complete list of options
-v, --verbose show detailed information
usage: pacpl --to <format> <options> [file(s)/directory(s)]
PACPL(1) User Contributed Perl Documentation PACPL(1)
NAME
Perl Audio Converter - multi purpose converter/ripper/tagger
SYNOPSIS
DESCRIPTION
CAF, CDR, FAP, FLA, FLAC, IRCAM, LA, LPAC, MAT, MAT4, MAT5, M4A, MMF,
RAW, SD2, SF, SHN, SMP, SND, SPX, TTA, VOC, W64, WAV, WMA, and WV...
NAME
SYNOPSIS
DESCRIPTION
kmdr-executor /etc/pacpl/mods/pacpl-gui.kmdr
With the Hardy:
sudo apt-get install faac faad ffmpeg sox flac lame mppenc wavpack
