posting problem ,link,
    [SOLVED] posting problem ,link,
    this is the only one I have taken note of as yet ,,,https://www.kubuntuforums.net/showth...m-with-posting
    And that one's fixed.
    Slava Ukraini! πŸ‡ΊπŸ‡¦
      lets see
      edit ,,,not at hear ,,,,let me reboot and see 1 more time
        1 more time
        edit ,,,,going to try a diferent browser now ,,,,,not working in firefox-57.04
        chrome wont even reload the page and gives this error
        This page isn’t working
        www.kubuntuforums.net is currently unable to handle this request.HTTP ERROR 500
          and with chrome ,,,,,,,,
            will try a different install ,,,,this was all done in the Kubuntu-16.04-with Neon-/dev/stable repo
              vinny: You are posting here, so it is working. The notice about this new sub-forum is in Kubuntuforums Announcements, and that is restricted to Administrators and a select other few KFN members.
                yes the sub-forum is working ,,,,,posting a reply is not as stated in the link in post-1 hear.
                I get a blank page when hitting the "Post Quick Reply" button ,,,,,in firefox I can refresh the page and get a "duplicate post"message then get redirected to the posted mesage.
                in chrome even refreshing the page dose not work with the posted error in post-4 at hear
                  now in Kubuntu-17.10
                  nope same behavior ,,,,,,I'll make a screancast to illustrate.
                    test
                      vid of problem
                      hear have a look
                        That issue we know about. It isn't that you aren't able to post, it's that the posting doesn't return you to the page you were on afterwards. We've see this even before this current upgrade to vBulletin. I't annoying for sure, but posting still functions.
                        This, and possibly the other reported issues since the upgrade, are likely all due to the upgrade of PHP, not vBulletin. Open Source is looking at that. He will see about either downgrading PHP back to version 5.5 (what we were running), or to version 5.6.
                          Aaaa well it's the first time I'v seen it
                            Prior to this time (this upgrade), it happened to 'some' but not 'others'. It is now affecting everyone. However, there is a 'workaround' that seems to work; it did for the last reply I just made.
                            Type your reply and click the Preview Post button and then the Submit Reply button.
                            Damn! It didn't work for this reply. Oh well.
                            Double damn!! Editing a post works as expected.
                              test
                              edit ,,,still experiencing the anomaly ,,,,but yes the edit function works
