I'm using Kgrab. I don't see a way to crop the image it gets. What program should I be using?
How to greatly improve the sharpness/clarity of Kubuntu's fonts, lines, images?
Originally posted by RLynwood View PostI don't see a place in the System Settings for changing themes; where's that?
but you can tweek all the colors in a theme and system in system settings>application appearance>colors colors tab
Pan-Galactic QuordlepleenSo Long, and Thanks for All the Fish
- Jul 2011
- 9524
- Seattle, WA, USA
- Send PM
Originally posted by RLynwood View PostI'm using Kgrab. I don't see a way to crop the image it gets. What program should I be using?
Thanks. That was very helpful. I used kgrab because I thought the pkg mgr described it as being more versatile than ksnapshot, but either I misinterpreted it or it was wrong; it appears that ksnapshot is considerably more versatile than kgrab. I've installed kipi-plugins and will follow your instructions hereafter.
Originally posted by RLynwood View PostThanks. That was very helpful. I used kgrab because I thought the pkg mgr described it as being more versatile than ksnapshot, but either I misinterpreted it or it was wrong; it appears that ksnapshot is considerably more versatile than kgrab. I've installed kipi-plugins and will follow your instructions hereafter.
first I click save as ,,,,then open the snapshot with gwenview and use the "send to" button from their.
Originally posted by vinnywright View PostI find ,,,,,(and maby I'm doing it wrong) that the "send to" button in Ksnapshot is misleading in that if you JUST use it from the Ksnapshot window as soon as you take the snapshot it dosent work,,,,,,,,the file/snapshot has not been saved yet so cant be sent.
