Installing Kubuntu on a Second Hard Drive Without CD
    Fancy yourself a real tech nerd? Let's see if you can solve this one.
    I have a HP laptop, running Windows Vista 320gigs of space distributed over two hard drives. Right now only one is being used, and I think it would be convenient to install Kubuntu on my other hard drive (this should save me from losing my data, right?)
    The only problem is that I cannot seem to burn the Kubuntu ISO onto a CD. I am using Infarecorder and the MD5 checker said the keys matched. I have no experience with Kubuntu and all the installation guides online are either way beyond my comprehension level or they involve burning it to a CD (by the way, the exact error I get is "A write error occured. Failed to write lead-in" and yes, I lowered the write speed.)
    So, I want to (hopefully this isn't ambitious or demanding) :
    Install Kubuntu 8.10 on my second hard drive
    Not loose all my information
    Burn without a CD or fix the problem I have burning the CD.
    Any help would be rewarded with praise and little dances and whatnot.
    Re: Installing Kubuntu on a Second Hard Drive Without CD
    Have you seen https://help.ubuntu.com/community/BurningIsoHowto ?
    "A problem well stated is a problem half solved." --Charles F. Kettering
    "Sometimes the questions are complicated and the answers are simple."--Dr. Seuss
      Which version of Kubuntu LiveCD did you download? Intrepid 8.10 is 692M.
      Slava Ukraini! 🇺🇦
        ... or maybe just an old nerd.
        Never heard of that -- so of course that's my first suspicion.
        This will sound facetious, and it is admittedly a non-technical solution, but I'm serious .... sometimes you just need a friend with a plain-Jane Windows computer and a blank CD. I think it's some combination of your hardware and your burning software, and you might get a quicker result with the friend's rig than you will chasing gremlins around your Infarecorder-whatchamajig.
          Infarecorder is the program suggested by Linux to do the burning with. I'd never heard of it either
          Originally posted by arochester
          I have, and I did that to the T.
          Er...is 8.10 the correct answer to that? I'm going with 8.10. It's 8.10.
          EDIT: Ah! Did it the old fashion Windows Explorer way ("right click->send to->D:") and it says the disk is too small (by 4mb. Groan)
          EDIT2: Eureka! It's burning! Any help on the issue of the dual drives? Is there any online articles that could help me out?
            although not being a geek or nerd here is my nerdy solution:
            http://www.linuxbasement.com/content...t-burning-a-cd
            This is for a 64bit setup if you have a 32bit setup then you will have to look for those files here:
            http://archive.ubuntu.com/ubuntu/dis...-i386/current/
            I works fine. enjoy
            4 GB Ram
            Kubuntu 18.10
              I got that sorted out (Check my two edits)
              Thanks though!
              Any thoughts on putting it on my second drive?
              EDIT: Now that I look at it, and from what I've read; it should install to my D: drive regardless. Nevermind, thanks gents and ladies.
