SE P990i on Kubuntu - HELP!
    HI, I tried pluging in my Sony Ericsson P990i to my kubuntu box with the cable that comes with the package. I see the phone is charging but I cannot find the icon of P990i on the desktop or elsewhere. So I tried issuing command "lsusb" and I get output
    Bus 004 Device 001: ID 0000:0000
    Bus 001 Device 003: ID 0fce:d030 Sony Ericsson Mobile Communications AB
    Bus 001 Device 001: ID 0000:0000
    Bus 003 Device 002: ID 046d:c518 Logitech, Inc.
    Bus 003 Device 001: ID 0000:0000
    Bus 002 Device 001: ID 0000:0000
    My aim is to be able to connect/sync my phone to kubuntu box, so i could sync my address book, transfer files, and install application!
    Your thought and response to this matter is hightly appreciated!
    Thanks!
    Re: SE P990i on Kubuntu - HELP!
    there some appz to sync mobile phones. dunno if they support yourse but you can try.
    gnokii an kmobiletools
    i had no luck with my phone . on there site there is also a list of support.
      Hi I tried to install gnokii an kmobiletools.. gnokie doesnt run, it open the splash window but nothing happens. On the Kmobiletools, it says thatt I dont have device plugin. It asking for a device address.. /dev/what_device. however, I do not know where the P900i mount or if it mounts. When I plugin the P990i on USB. no icon shows on the desktop, unlike with thumbdrive or in memory card readers.
      Also, I have a bluetooth and was able to transfer files from pc to phone vice-versa... can I use this also for a connection to kmobile or any mobile phone 3rd party software ?
      Your thoughts and response will be highly appreciated!
      Thanks.
        I don't have a P990i so I can't help much, but want to add that Kubuntu Edgy can detect my K750i's memory card.
        cheers!
        -=|From the desk of|=-
        «•´¨*•.¸¸whoiam55.¸¸.•*¨`•»
        Reg. Linux User # 400637
