Suspend2 not work
    Suspend2 not work
    Hello,
    I install "sudo apt-get install hibernate", then run:
    al@ub:~$ sudo hibernate
    Your kernel does not have any recent Software Suspend 2 support compiled in.
    Please follow the HOWTO linked from http://softwaresuspend.berlios.de/ for
    instructions on how to compile Software Suspend into your kernel.
    hibernate: Aborting.
    http://softwaresuspend.berlios.de/ link not work.
    That need make, that work "sudo hibernate"?
    Re: Suspend2 not work
    Try http://www.suspend2.net/ You may need an older version, though for the 2.6.17-10 kernel.
