internet problem
    internet problem
    so i'm using 6.06 and when i try to view non www. webpages ex. [http://gparted.sourceforge.net/] it says the conection with the server was broken if i try again it might load or it might not any ideas?
    Re: internet problem
    At the moment (14.10 17.45 - Zurich, CH) the site http://gparted.sourceforge.net seems to be off line, while http://slashdot.org/ seems to be fine ... maybe you've had bad luck?
    Birdy
